Ricoh MP2000: Scanning to SMB Folder on Windows 10 - Software & Driver Assistance Needed
_pucio 10320 15
How can I scan from a Ricoh MP2000 to a Windows 10 shared folder, or is there newer software/driver for this model?
There is no dedicated Windows 10 software for the Ricoh MP2000, so the practical options are FTP scanning or changing the SMB setup rather than looking for a newer driver [#16517960][#16514825] A simple workaround is to run an FTP server on the PC, point the copier to that address, and enter the user name and password; one user reported that this works without problems [#16514825][#16516639] If you want to keep SMB, one reply reported success on Windows 10 by enabling SMB2 on the PC with `Set-SmbServerConfiguration -EnableSMB2Protocol $true` and setting the Ricoh side to `msh> smb client auth 1` [#18898674] Another reply warns that turning SMB1 back on in Windows is unsafe and recommends firmware updates, a proxy/server machine, or alternative protocols such as FTP or SMTP instead [#18965627]
  • #1 16514758
    _pucio
    Hello, I can't scan to a folder from windows 10 (it works fine on xp) from what I already figured out, it's probably the old software in MP2000 (this is NIB: 6.04.4k).
    Can any of the honorable colleagues help? has newer software.
    I've been looking for two days and only drivers and nothing else.
  • #2 16514825
    jurmun
    Help: 7
    Rate: 17
    I've been struggling with smb scanning on Conicy copiers recently, generally I advise you to set up an ftp server on your computer and ftp scan, I can include a simple and small ftp setup program if you wish. Generally speaking, this is the easier solution in my opinion.
    Regards, Jurmun!
  • #3 16516306
    _pucio
    I would prefer via a network folder, but time is running out for me and I have to run a scan.
    Jurmun - how you can share your knowledge :)
  • #4 16516424
    henryxxl
    Help: 32
    Rate: 104
    Konica Minolta always scans via smb without any problems, so either my colleague has an archaic model or cannot set it up. In ricoh the firmware update will help and smb will work (as in most ricoh), but I don't have the firmware for this model.
    best regards
  • #5 16516639
    jurmun
    Help: 7
    Rate: 17
    Exactly I had a problem with the bizhub C253 and I didn't have time to bother with it.
    I installed ftpserver on the computer, indicated the folder to which the scans should go and that's it, the rest of what to do was indicate the address of this folder on the device, enter the user and password. Most importantly, it works without a problem.
    • FTPServer.exe (355 KB) You must be logged in to download this attachment.
  • #6 16516653
    copyman
    Photocopiers specialist
    Help: 1107
    Rate: 836
    After all, you do the same scan to SMB in C253 :) You create a folder, share it with full permissions to the Everyone group, disable password-protected sharing and on the machine you only enter the name displayed on the desktop, the host name (full computer name) and the path to the folder :) What like what, but Konica Minolta has a really simple SMB scan setup system - no additional software, no firmware updates, etc.
    C.
  • #7 16516672
    jurmun
    Help: 7
    Rate: 17
    The topic is about Ricoh MP2000, I just described a different solution to the scan to file problem.
  • #8 16516793
    _pucio
    Then let's go back to the main direction Ricoh MP2000 has anyone the latest firmware for this model and can share?
  • #11 16517960
    benek2
    There was no software for Windows 10 for this model
  • #12 16554419
    SanceS
    Help: 27
    Rate: 48
    I do not know if it will help, I sent you the driver via PW
  • #13 16554480
    Ricoh_220
    Help: 464
    Rate: 754
    Check the PW mailbox.
    If it does not help, scan the email or ftp another solution is a file server on another machine with a different supported system /
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
  • #14 18898674
    wilkunek
    Rate: 15
    The solution to the problem for me was to use this page:
    Link
    I was helped on SMB Windows 10 2004 Ricoh MP C6003
    Summary for the lazy
    Enter ricoha telnet, change
    in Windows powershell after enabling all options
    SMB Set-SmbServerConfiguration -EnableSMB2Protocol $true
    If the prospective solution seeker does not understand what I wrote in the summary, read the solution from the link slowly. I didn't understand until the third reading, so take your time and you'll be fine.
  • #15 18898979
    jaxu
    Help: 10
    Rate: 12
    From myself I will add that some time ago the windows 10 update disables the SMB protocol in version 1 and 2 in windows.
    In order for it to work properly with some printers, you need to restart it (how to do it I send to uncle google)
  • #16 18965627
    SanceS
    Help: 27
    Rate: 48
    The advice to run SMB 1.0 on Windows systems is very inappropriate and dangerous advice. Microsoft has disabled the SMB 1.0 protocol because a known vulnerability in this protocol could allow unauthorized access to the computer.
    Correct solution to this problem:
    1- Updating the firmware of the device, if the manufacturer has prepared an appropriate update
    2- Launch a server / proxy computer that will be used to capture files from printers (SAMBA SMB 1.0) and will allow these files to be downloaded by computers on the network via SMB 3.0 protocol
    3- Use of other available protocols, ftp, smtp
The discussion revolves around the Ricoh MP2000's inability to scan to an SMB folder on Windows 10, a feature that works on older systems like Windows XP. Users suggest that the issue may stem from outdated software or firmware. Some recommend setting up an FTP server as an alternative solution, while others emphasize the need for a firmware update to enable SMB functionality. There are mentions of other brands like Konica Minolta, which reportedly have simpler SMB setups. A few users highlight the risks associated with enabling SMB 1.0 due to security vulnerabilities and suggest using alternative protocols or a proxy server for file transfers.
