RICOH Aficio MP C2051 - Scan to Folder on Windows 10 Setup Guide, Troubleshooting & Service Tips
luto1985 6165 1
  • #1 16973689
    luto1985
    Hello. How to set scan to folder on above mentioned device to windows 10. I know that a new user is being created. I also create a folder that I share and the device sees it, but not when I click, scan it and the file in the folder is not there. It will be the 3rd computer. The previous two were set up by a service technician. The computer is new. sees the device. I have no idea where to start.
    I did everything in turn, as in this video https://www.youtube.com/watch?v=daijaCPWSBs only it is a different device model. And I was so happy that it will succeed ... and here is the button
  • #2 16978853
    malik123
    Help: 11
    Rate: 37
    I was plugging in the scanner today. Scan to Folder I mean saving a scan file in a preconfigured format to a predetermined folder, triggered by pressing a button on the device? the appropriate application for this device, which you will probably find on the manufacturer's website, next to the drivers, do not worry if you do not find the W10, intended for older systems should also work.
