Asus X533M - Keyboard and touchpad does not work in the system, works in the bio
Primo_84 5976 11
Why do the built-in keyboard and touchpad work in BIOS but stop working as soon as the operating system boots on an Asus X553M laptop?
The most likely cause is a Windows key filter / Keyboard Device Filter problem, not a hardware fault: check whether there is a key-filter icon near the clock in the installed system, and if so install Keyboard Device Filter Utility and disable the filter [#16527782] [#16529137] A clean reinstall of the system with the proper drivers was also suggested as a test [#16518493] One reply advised checking BIOS Legacy USB settings, especially if you are testing external USB input [#16518500] If the filter is not present and reinstalling or reflashing BIOS does not change anything, the remaining suspicion is a motherboard/KBC defect [#16529120]
  • Keyboard and touchpad fail only after boot
    #1 16518461
    Primo_84
    I have a problem with the Asus X553M laptop.
    A client came to me with a damaged motherboard. Apparently the laptop was flooded before and something burned. So I tested the memory and disk.
    Memory and disk turned out to be functional, so I ordered and installed the CD. Everything works fine except the keyboard and touchpad.
    When I enter the bios, the keyboard works. But as soon as the system boots, it immediately disconnects. I've tried everything. I started the laptop with the battery removed and the battery without power. I even started the bootable WinPEE system, and it doesn't work either. I also have a Mint Linux CD, I booted and opted out Linux and nothing else. Best of all, when I have the windows login screen and press the power button to enter sleep mode, after pressing any key the system restores, so the keyboard works when the system is asleep. I suspect that the reason is not some motherboard layout, but the keyboard. Maybe it causes a short circuit and that's why the system disconnects it. But I am not sure, so please help me solve the problem and thank you in advance.
    dlusio
    Help: 11
    Rate: 40
    Maybe try to install a clean system with drivers, we'll see what the effect will be. Rather, laptops do not protect themselves so that they disconnect the keyboard and touchpad.
    Mobilny Serwis AGD LENKA
    Różana, Kraków, 32-020 | Tel.: 798XXXXXX (Show)
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    View the settings in Bios
    Legacy USB> Disabled
    _______________________________
    Is the USB keyboard working?
  • #4 16518652
    Primo_84
    under usb the mouse and keyboard work.
    If this is the system's fault, it should work under linux linux. When installing the system, it also does not work, I have to have a USB keyboard and mouse connected. I will try to reinstall the system. I read somewhere that a function key can send a signal all the time, that's why it works in the bios because the function keys don't work there.
  • #5 16518768
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    You haven't written anything regarding checking on a connected keyboard and / or touch only.
  • #6 16519778
    Primo_84
    Nothing happens on the tocho or the keyboard itself.
  • #7 16527561
    Primo_84
    I ordered a new keyboard with a touch and they don't work either. I reinstalled the system with a connected keyboard and mouse and nothing else.
    Maybe it's the bios fault or the main board itself?
  • #9 16529120
    dlusio
    Help: 11
    Rate: 40
    I will say Yes, it may be a matter of bios or the KBC system itself, but if it was a kbc system then the bios keyboard would not work. If there is a new system installed, then I would focus more on the motherboard itself. First, reprogramming the bios, if a friend wants it, I can look for a 100% functional because I have already repaired these motherboards.
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    I worked on such a problem in a similar Asus - only the key filter was to blame - and before I got to it was the third keyboard, the second touchpad, replaced KBC, reprogrammed KBC and BIOS.
    Run the original system and check if you don't have a key filter icon next to your watch.
    If not, install Keyboard Device Filter Utility and disable the filter.
  • #11 16532898
    Primo_84
    I was flashing Bios too. I will check with the filter and let you know.
  • #12 16552366
    Primo_84
    Everything indicates a motherboard defect. But I had to give my laptop to the customer. Also, thank you all for your help.
The discussion revolves around an Asus X553M laptop experiencing non-functional keyboard and touchpad after a motherboard replacement due to water damage. The keyboard works in BIOS but disconnects upon booting the operating system. Various troubleshooting steps were suggested, including checking BIOS settings, reinstalling the operating system, and testing with external USB devices. The possibility of a key filter being activated was raised, as well as concerns about the motherboard or keyboard controller (KBC) being defective. Ultimately, the consensus leans towards a potential motherboard issue, as multiple keyboards and touchpads were tested without success.
