[Solved] CAL 534 TR Mower Transmission Oil: Suitable Type and Quantity for Effective Performance
Micha_zz 28023 6
  • #1 16520823
    Micha_zz
    Rate: 20
    what oil should be used and in what quantity for the transmission in the mower, drive as in the photo borrowed from another topic:
    CAL 534 TR Mower Transmission Oil: Suitable Type and Quantity for Effective Performance I have temporarily used a 5w40 engine because I didn't have anything else at hand and I wanted to check if the drive would start after repair, but if it turns out to be bad, I only need to know what. Someone encountered this case?
    Czyżycki
    Help: 75
    Rate: 197
    The type of oil does not matter in this class of gearboxes. You pour the engine (e.g. your 5W40) - it will be good, you pour the transmission (e.g. Hipol GL-4 80W / 90) - it will also be good. I also tested semi-fluid grease (ŁT-4 grease mixed with 15W-40 engine oil for cream consistency) and it also worked. These are not strenuous gears, designed for hard, long-term work.
    As for the amount of oil, it will probably be around 100 ml. The exact amount needed can be determined as follows:
    1 / to the transmission, lying in the position as in the picture, pour oil as much as it enters. The vent hole, which is firmly (if available) in the upper part of the housing (near the pulley) must first be closed. After twisting both parts of the gear, this hole must be unblocked. The most commonly used method.
    2 / to the oil pan, i.e. the bottom of the gear, pour max. oil. You put the rest of the gearbox on this oil pan and screw it on from below. Inconvenient method.
    3 / scanning the inside of the gear housing. Expensive method, requiring a scanner and a computer program.
    4 / calculation of the volume of the interior of the gear using double marked integrals. Archaic, time consuming and requires a lot of mathematical knowledge.
  • #3 16521442
  • #4 16521767
    Micha_zz
    Rate: 20
    The axial holes will not spill out because there are sealants, unless they are no longer holding but so far there has been no leakage. I did as colleague Czyrzycki described, namely I poured into the lower bowl as much as I could (there are cutouts on the axle as in the upper housing as seen in the photo) and I turned the whole on silicone as it was originally. Initially, I poured into the upper bowl in the position as in the photo, but oil began to leak through the hole around the pulley, so I changed the concept and poured into the lower bowl. Even better, because it entered more than the top. I know this is a trivial thing, but the mower is from 2005 and the transmission showed no signs of wear, so I just want this state of affairs to last as long as possible. The more that the next newly purchased equipment will not serve so much time. Thanks for the answers.
  • #5 18750371
    witess
    Then write how much oil you have, maybe this information will be useful to someone.
  • #6 18962324
    Micha_zz
    Rate: 20
    I think 50, maximum 60 ml of oil came in. I would like to add that the gearbox has been working without a problem for 3 years, it would only be useful to replace the pulley before the next season. Fortunately available without any problems.
  • #7 18962327
    Micha_zz
    Rate: 20
    I think 50, maximum 60ml of oil went in. I would add that for 3 years the gearbox has continued to run without any problems, it would only be useful to replace the pulley before next season, much worn out from the belt. Available without a problem fortunately.
    Added after 4 [minutes]: .
    Topic resolved. Just to add that in another gearbox (viking) when I used engine oil the drive had a tendency to slip (especially uphill). Out of curiosity I changed to hydraulic oil and the problem disappeared.
The discussion centers on the appropriate type and quantity of transmission oil for the CAL 534 TR mower. Users suggest that both engine oil (like 5W40) and transmission oil (such as Hipol GL-4 80W/90) are suitable for the gearbox. The recommended oil quantity is approximately 50 to 100 ml, with methods for filling including pouring into the upper or lower bowl of the gearbox. One user noted that their gearbox has functioned well for three years with 50-60 ml of oil, indicating that proper sealing prevents leaks. The conversation emphasizes the importance of maintaining the mower's transmission for longevity.
