Pairing Chinese Remotes to VOTEX 4M1046V1C Switch: Step-by-Step Guide Needed
darekborus 16524 6
  • #1 16521402
    darekborus
    Hello. This manual would help me a lot if I had the original remote control and someone gave me a votex switch and some Chinese remotes and I don't know how to pair it, maybe someone will help me? In the attachment he adds a photo of the pilot and I am asking for help
    Moderated By CameR:
    Separated from the archival topic:
    https://www.elektroda.pl/rtvforum/topic3348909.html#16521745
    • Pairing Chinese Remotes to VOTEX 4M1046V1C Switch: Step-by-Step Guide Needed image.jpg (854.27 KB) You must be logged in to download this attachment.
  • #2 16521745
    CameR
    Moderator of Vehicle Security
    Help: 1141
    Rate: 3278
    darekborus wrote:
    and some Chinese remotes (...) how to pair it, can someone help me?
    Only with original Cobra 7727 or Cobra 7777 remotes!
    1) Set switch "2" to ON
    2) Press and hold both buttons on the remote control together
    3) when the remote control diode stops flashing and goes out - release the buttons
    4) the LED should light up steadily
    5) press the red button on the remote control once (do not hold it), the LED should blink several times - the remote control added
    6) pair the rest of the remotes by repeating steps 2 to 5
    7) Set switch "2" to OFF
    https://www.elektroda.pl/rtvforum/topic3215568.html#15743825
    • votex.pdf (779.59 KB) You must be logged in to download this attachment.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16521761
    darekborus
    Well, only those remotes that I have worked perfectly, only such a thing happened that the car was not used for several days and someone did not turn off the lamp on the ceiling, the battery was discharged and I could not start the car after charging the battery I started the car and the central locking stopped working and now no I know what is the problem of the batteries in the remotes have been replaced And despite this, the central locking still does not work I do not know what to do because as soon as the battery is discharged, the control panel could decode A the devices should definitely be operational
  • #4 16521764
    CameR
    Help: 1141
    Rate: 3278
    darekborus wrote:
    the remotes I have worked perfectly
    Then carry out the coding procedure of these remotes to the control panel in the car.
    ABC KOM
  • #5 16521765
    darekborus
    Only another problem is the coding procedure for the central lock that I have from votex concerns Pilots with two buttons I have this pillot that my mother has five buttons I tried in many ways and it fits in no way ? I do not fully understand that if the battery was dead, everything could be decoded
    Have you seen pictures of my remote control or do you know what his name is to find coding instructions from him?
  • #6 16522028
    CameR
    Help: 1141
    Rate: 3278
    Maybe someone has installed one more dedicated control unit for these pilots and you have found not the one that cooperated with these pilots?
    ABC KOM
  • #7 16522287
    darekborus
    Do you know what the control unit for these Pilots can be called? Or what can these Remotes even be called? So you advise looking for another switchboard, yes? Although the switchboard that is now, the wires to the door and the tailgate go from it, and all the doors and the trunk are closed with the key, i.e. the central locking works and the fault is probably in the non-coded remote controls
The discussion revolves around pairing Chinese remotes with the VOTEX 4M1046V1C switch. A user seeks guidance on pairing these remotes after receiving the switch without the original remote. Responses indicate that pairing is possible primarily with original Cobra remotes (Cobra 7727 or Cobra 7777) and provide a step-by-step procedure for pairing. Issues arise when the user experiences problems with central locking after a battery discharge, leading to confusion about the coding procedure for remotes with different button configurations. Suggestions include checking for compatibility with the control unit and ensuring the remotes are properly coded to the system.
