Blade Dislodging from Unidentified German Jigsaw During Operation
windows160 17295 12
Why does the blade fall out of my jigsaw during cutting, and what type of blade should I use?
You are probably using the wrong blade type; this jigsaw needs U-type blades, not the nose-type blades you were buying, and those should stay locked in properly [#16527079][#16529506] If the correct U-type blades still slip out, the blade holder/handle may be worn or damaged [#16526967] One reply specifically said that for Black & Decker blades this fault is usually in the handle, which costs about 30 PLN to replace [#16526972]
  • #1 16522331
    windows160
    Rate: 10
    I have some weird German jigsaw. I don't know which company or model because everything is worn. The handles that match her are the nose ones. The problem is that when I start cutting, the blade falls out after a while. Do you have any idea what could be the reason?
    Regards.
  • #2 16522464
    Hungryadmiral
    Rate: 12
    maybe you need to screw the key ?? I have the same model where I secure myself by tightening. Regards
  • #3 16522576
    windows160
    Rate: 10
    Only for me how to assume the saw blade does not need to tighten anything. You just put it on and there is a latch that holds it. When the jigsaw does not work, the blade holds firmly but when I start to work, it falls out after a while.
  • #4 16522601
    Hungryadmiral
    Rate: 12
    This nest must already be made.
  • #5 16522633
    windows160
    Rate: 10
    Do you have any ideas for repair? Because the entire jigsaw works only this socket ...
  • #6 16522683
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    What kind of jigsaw, what manufacturer, model. Take at least a picture.
  • #7 16526925
    windows160
    Rate: 10
    I was able to learn a little more about this jigsaw. This is Black & Decker KS631 400W. Below I send photos of the head and surroundings.
    Blade Dislodging from Unidentified German Jigsaw During Operation Blade Dislodging from Unidentified German Jigsaw During Operation Blade Dislodging from Unidentified German Jigsaw During Operation Blade Dislodging from Unidentified German Jigsaw During Operation Blade Dislodging from Unidentified German Jigsaw During Operation
    And here a crack, maybe it's guilty?
  • #9 16526972
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    If you have Black & Decker saw blades, this is the fault of the handle, which costs around 30 PLN.
  • #10 16527008
    windows160
    Rate: 10
    I usually bought saw blades for a few zlotys in castorama. They have these nose tips, without any screw holes or something.
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    You should buy U type blades, not nose blades. More at Google's uncle.
  • #12 16527112
    windows160
    Rate: 10
    Oki, I'll buy and see :) thanks so much for your help.
  • #13 16529506
    windows160
    Rate: 10
    And yet bad saw blades. These type U fit perfectly and nothing falls out :)
    Jerry1960 thanks so much for your help ;)
The discussion revolves around a user experiencing issues with a German jigsaw, specifically a Black & Decker KS631 400W model, where the blade dislodges during operation. Initial suggestions included checking the blade attachment mechanism and ensuring proper tightening. The user clarified that the jigsaw uses a latch system rather than screws. Further responses indicated that the problem might stem from using incorrect blade types, with recommendations to switch to U-type blades instead of nose blades. The user confirmed that after changing to the appropriate U-type blades, the issue was resolved.
