VOLVO S60 D3 2011 - Connecting daytime running lights with a dusk module
r_putek 7458 11
How can I connect aftermarket LED daytime running lights and a dusk module to a 2011 Volvo S60 D3 without triggering bulb-out errors?
There is no factory DRL/twilight-sensor interface on this Volvo, and the existing sensor is only a sun sensor for the instrument backlight and air conditioning, not a true dusk sensor [#16526402] If you interrupt the headlight bulb circuits with a relay, it will probably trigger a blown-bulb warning [#16529179][#16529215] The only workaround suggested in the thread is to enable the car’s automatic “lights on after engine start” function, because the daytime running lights go out when dipped beam is on [#16526408][#16526642] That still does not give you a dedicated factory connection point for a dusk module that cleanly switches dipped and parking lights off during the day. The thread does not provide a confirmed wiring point that avoids errors [#16526402][#16529179]
  • #1 16524456
    r_putek
    Rate: 10
    Gentlemen, I want to connect a set of LED daytime running lights with a twilight module that turns on the daytime running lights during the day and turns them off after dusk and turns on the dipped and parking lights.
    Does anyone know where I can connect to the installation so that the module disconnects the dipped and parking lights and does not release any error or information about a blown bulb?
  • #2 16525368
    piotrekwoj1
    Help: 947
    Rate: 3433
    Does your Volvo have a twilight sensor factory fitted?
  • #3 16525380
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If you don't have it, install the factory one.
  • #4 16526402
    r_putek
    Rate: 10
    It has a so-called sun sensor. It is not a typical twilight sensor. The computer uses it to change the backlight of the clocks (it illuminates the clocks brighter in the sun) and to control the air conditioning. But there is no factory-fitted daytime running light configuration for this model.
    I want to install an external twilight sensor and I am looking for a place to plug it in so that it turns off the dipped and parking lights.
  • #5 16526408
    Help: 1405
    Rate: 6430
    You can activate the 'turn on lights' after starting the engine.
  • #6 16526486
    r_putek
    Rate: 10
    Can be turned on, but automatic dipped beam.
  • #7 16526642
    piotrekwoj1
    Help: 947
    Rate: 3433
    And that would be enough, even if the daylight burned all the time, they would take a negligible electricity. The daytime lights go out when the dipped beam is lit.
  • #8 16529062
    r_putek
    Rate: 10
    Yes, but the dipped beam when set to automatic switch on after the engine is started - regardless of whether it is day or night. And I want to plug in a twilight sensor which is to disconnect the dipped headlights during the day, regardless of how they will be turned on or with an automatic or switch.
  • #9 16529166
    Help: 1405
    Rate: 6430
    This can be tricky, but you have to plug directly into the bulb circuits.
  • #10 16529179
    r_putek
    Rate: 10
    I am wondering about this solution, but I am afraid that if I stick with the relay in the bulb circuit in front of the bulb, which disconnects the wire going to the bulb, it will throw out an error about a blown bulb.
  • #11 16529215
    piotrekwoj1
    Help: 947
    Rate: 3433
    It will probably happen.
  • #12 19954073
    P.slon
    And how did it go with those lights? I have the same problem.
The discussion revolves around connecting LED daytime running lights to a Volvo S60 D3 2011 using an external twilight module. The user seeks guidance on how to wire the module to ensure it turns off the dipped and parking lights without triggering bulb failure errors. Participants clarify that the vehicle has a sun sensor but lacks a factory twilight sensor. Suggestions include activating the 'turn on lights' feature after engine start, but concerns arise about potential errors when disconnecting the bulb circuits. The consensus indicates that direct wiring into the bulb circuits may lead to error messages regarding blown bulbs.
