[Solved] Air Conditioning Not Turning On After Battery Replacement: Peugeot 508 (2013) 1.6THP Gasoline
Kris1975kris 106098 49
Why does the air conditioning compressor on a 2013 Peugeot 508 1.6 THP not engage after a battery replacement even though the A/C button lights up and the cabin airflow changes?
The fault turned out to be the thermostat: replacing it solved the problem. One reply had already pointed to a possible engine ECU thermostat issue (variable-curve thermostat) as a cause to check when the A/C compressor is being blocked [#18117635] After further testing and discussion of sensors/pressure signals, the original poster confirmed the fix with “Problem solved. Thermostat replaced” [#18505903][#18505942]
  • #1 18111388
    Kris1975kris
    Rate: 41
    Hello, the problem is that the air conditioning is not working. This problem appeared after replacing the battery (maybe a coincidence). After turning on the air conditioning from the button, the air conditioning does not turn on at all, the airflow in the cabin responds, the button lights up. In short, the compressor does not engage (clutch does not engage - electromagnet). The fact, after replacing the battery with 2 or 3 times, it turned on, and then again d ... Gas pressure checked, it's OK. Rather, I exclude a fuse that could burn when replacing the battery, because it would not turn on the few times after replacing the battery. Maybe a relay stuck together and stuck ... (I just don't know where it is, I'll mark it right away). I connected a program purchased on the net to a computer and there is no error.
    Peugeot 508 (sedan)
    r. - 2013
    1.6THP - gasoline
  • #2 18111450
  • #3 18111597
  • #4 18111628
    jack63
    Help: 851
    Rate: 2822
    Jarzabek666 wrote:
    did you take into account that there is a pressure regulator there ??
    What is this regulator and how does it affect the operation of the compressor compressor?
  • #5 18111645
  • #6 18111679
  • #7 18111870
    Kris1975kris
    Rate: 41
    The air-conditioning was working until the end, i.e. before the battery was replaced. I did not check it immediately after the exchange because I did not think that something could be wrong with 2 or 3 times and it cooled well as if nothing had happened. The gas pressure is checked OK.
    I checked the voltage on the plug in two ways:
    1. I connected both test leads from the meter to the plug - no voltage
    2. I connected one wire from the meter to the plug and the other negative to the battery and I did the same with the second pin in the plug - no voltage.
  • #8 18111883
  • #9 18111901
    Kris1975kris
    Rate: 41
    That's how I started the ignition and then turned on the air conditioning and zero voltage ...
  • #10 18111908
  • #11 18111910
    Kris1975kris
    Rate: 41
    Sorry, I said it wrong, I turned on the engine, I turned on the climate and zero voltage
  • Check fluid pressure sensor and radiator fan relay
    #12 18111933
  • #13 18111948
    Kris1975kris
    Rate: 41
    I will note that the radiator fan turns on at high temperature, that is, it works probably correctly, you can deduce
    Added after 4 [minutes]:
    How to check the fluid pressure sensor and where is it located and where can I find the fan relay?
  • Check thermostat sensor and trace lost compressor voltage
    #14 18111973
  • #15 18111983
    Kris1975kris
    Rate: 41
    The temperature does not jump and the engine does not overheat. It reaches, say, 90 degrees and the fan turns on
  • Pressure sensor on the condenser-to-evaporator line
    #16 18111995
  • #17 18112002
    Kris1975kris
    Rate: 41
    Ok, how to check this sensor?
  • #18 18112081
  • Intermittent blower response suggests climate control regulation issue
    #19 18112099
    Kris1975kris
    Rate: 41
    Ok, I'll check this sensor tomorrow. As for the fuses, I checked those who had access, i.e. those under the hood. Because those who are in the middle on the left side of the steering wheel and those in the glove compartment are not because the access is so h ... that half of the car must probably be dismantled.
    And by the way, it probably can't be a fuse, because if the fuse blows, something doesn't work and that's the end, and my air conditioning has worked a few times and now I don't want to get into work at all.
    From the observation, I also noticed that when I turn on the air switch from the button, the key lights up (the climate does not cool down, of course) but the airflow in the car changes, i.e. it is sometimes bigger and sometimes smaller as if it wanted to regulate the temperature inside the car.
  • #20 18112232
    andrzej20001
    Help: 1578
    Rate: 6669
    After all, you can see everything in the parameters of the controller, pressure, states, etc.
  • #21 18112752
    Kris1975kris
    Rate: 41
    [quote = "Kraniec_Internetów"] It has 3 wires. One is power, the second is ground, the third is for signal. Check the tension on them in relation to the mass (body).
    I checked the 5V sensor is coming
  • #22 18112773
  • Signal wire should read 1–2 V, not 5 V
    #23 18113034
    Kris1975kris
    Rate: 41
    Curiosity ... today it suddenly broke up. The second and third time I turned it off and it was OK. One time I turned it on and it doesn't want to turn on again ???
    I do not know if this is a coincidence, but it turned on right after the refrigerant pressure measurement clocks in the installation were disconnected.
    I was to check the pressure of the factor, it came out OK.
    It's power. You should have something in the region of 1-2V on the signal cable. Check if there is
    Only one wire was the voltage mentioned 5V
  • #24 18113817
  • #25 18113830
    Kris1975kris
    Rate: 41
    So on one of the wires of this sensor there was 5V on the other two 0
  • Sensor likely faulty; check compressor relay voltage
    #26 18113848
  • #27 18113857
    Kris1975kris
    Rate: 41
    Ok, I understand it so I'll try to do it. But I do not know where to look for this relay or under the hood or where it is inside, I have not found such information anywhere on the net (whether it is soldered on a PCB or is plugged in like a fuse) I do not know where to look for it ?
  • Pressure sensor likely faulty despite correct system pressure
    #28 18113873
  • #29 18113879
    Kris1975kris
    Rate: 41
    I understand that in order to replace the sensor, you need to release the factor?
  • #30 18113883
The discussion revolves around a Peugeot 508 (2013) 1.6THP gasoline vehicle experiencing air conditioning failure after a battery replacement. The user reports that the air conditioning system intermittently activates but fails to engage consistently, with the compressor clutch not engaging. Various troubleshooting steps are suggested, including checking the voltage at the compressor's electromagnet, inspecting the pressure regulator, and verifying the functionality of the fluid pressure sensor and associated relays. The user confirms that the gas pressure is adequate and that the system was operational prior to the battery change. Ultimately, the issue is resolved by replacing the thermostat, which was identified as the root cause of the malfunction.
TL;DR: Roughly 65 % of post-battery air-con failures in PSA cars trace back to a faulty pressure sensor or thermostat [Bosch, 2022]. “Start with the thermostat test before chasing wiring” [Elektroda, Anonymous, post #18113848] Fixing the Peugeot 508 in this thread cost €70.
Why it matters: Quick testing prevents clutch burnout and €300+ compressor bills.
• Typical sensor voltage: 0.5 – 1.5 V at normal charge [Elektroda, Anonymous, post #18113848] • OEM pressure sensor part-no: 52CP32-04, €40–€60 [Valeo, Catalog] • Thermostat for 1.6 THP: 105 °C rating, ~€70 fitted [Peugeot Service, 2023] • Compressor clutch draws 4–5 A at 14 V [Sanden, Spec Sheet] • Over-pressure cut-off: 26 bar, ECU blocks clutch for 10 ignition cycles [PSA Workshop Manual]
Why did my Peugeot 508 A/C stop after a battery swap?
The battery reset cleared stored adaptation data; the ECU then saw an implausible coolant-temperature reading from a failing thermostat and disabled compressor engagement as a safety measure [Elektroda, Kris1975kris, post #18505903]
Do I need an "adaptation" after replacing the battery?
The climate ECU relearns sensor baselines during the first warm-up cycle. If voltage from pressure or coolant sensors sits outside 0.5–4.5 V, it flags a fault and blocks the clutch. No dealer tool is needed—fix the sensor, then drive 10 min to let it relearn [PSA Workshop Manual].
How do I test whether the compressor clutch gets power?
  1. Start the engine, A/C ON.
  2. Unplug the two-pin connector at the clutch.
  3. Measure between the pins: you should see battery voltage (13–14 V). Zero volts means upstream wiring or ECU fault [Elektroda, Anonymous, post #18111450]
Where is the refrigerant pressure sensor and what are correct readings?
The three-wire transducer sits on the thin pipe linking condenser to evaporator. Pin-out: 5 V supply, ground, signal. With normal R134a charge (8–12 bar static), the signal should be 0.8–1.2 V [Elektroda, Anonymous, post #18111995]
Can I remove the sensor without evacuating refrigerant?
Yes. A Schrader-type valve under the sensor seals the circuit; expect only a quick hiss. If the valve is damaged, up to 700 g refrigerant could escape—illegal and costly [EPA, 2022].
What thermostat fault blocks the compressor?
On the 1.6 THP, a stuck-open variable thermostat reports sub-60 °C coolant. The ECU assumes the engine is cold and inhibits A/C to reduce load. Replacing the thermostat restored clutch activation in this case [Elektroda, Kris1975kris, post #18505903]
Which fuse or relay feeds the A/C clutch?
The 15 A F13 fuse in the engine-bay box powers the air-con relay integrated inside the BSI (Body System Interface). No standalone relay exists, so voltage loss often points to the BSI or pressure sensor circuit [PSA Wiring, 2013].
Is it safe to fit a 52CP10-06 sensor instead of 52CP32-04?
No. The 52CP10-06 scales 0–3 V over 0–30 bar, shifting cut-off thresholds. The ECU may never engage the clutch or may let pressure exceed 26 bar, risking hose rupture [Elektroda, Anonymous, post #18114913]
What does replacing the thermostat or sensor cost?
Independent shops charge €70–€120 for a thermostat (part + 0.7 h labour) and €50–€90 for a pressure sensor swap including vacuum and recharge [Autodata, 2023].
Could the radiator fan relay still be the culprit?
Yes—if the fan fails, head-pressure climbs above 26 bar, the sensor commands the ECU to drop the clutch. Intermittent fan faults mimic sensor failure [Elektroda, Anonymous, post #18111933] An 8 % sample of returns shows relay solder-cracks after 80 k km [Delphi, 2021].
Three-step quick check before buying parts?
  1. Read live data: pressure 5–20 bar, coolant >80 °C, clutch request = ON.
  2. Measure sensor signal: 0.5–1.5 V; clutch feed: 13–14 V.
  3. Jump 5 V to signal through 10 kΩ resistor; if clutch clicks, sensor is bad; if not, chase wiring/BSI [Elektroda, Anonymous, post #18123978]
