The bottom of the laptop is flooded - it does not react to anything
Kurczak1234 5619 7
  • Internal battery likely needs disconnecting after spill
    #1 16540278
    Kurczak1234
    In an unfortunate accident, I poured a large amount of water on the table, my laptop was lying on the table, and therefore it was flooded from the bottom. I disconnected it from the net and wiped the entire underside. I didn't turn it on all day, wanting it to dry. However, after this time, wanting to check if it works, I tried to turn it on (with and without the charger), but the laptop does not respond in any way. I would like to add that this is ASUS, from which you cannot remove the battery yourself, so it stayed inside ... Please let me know what could have happened and whether there is a chance to repair the computer.
  • #2 16540290
    bearq
    Help: 414
    Rate: 1613
    Call the fortune teller it will tell you :) Return the laptop to the appropriate service that will diagnose the fault.
  • Laptop flood cleanup and motherboard drying advice
    #3 16540367
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    Well, what kind of advice do you expect?
    Normally, such equipment is dismantled, all power removed, and the motherboard is washed with isopropyl alcohol, sometimes with distilled water, and then again with alcohol. Sometimes it dries thoroughly for two or three days. It should be ensured that the water does not get into the BGA systems best. Then it checks if it worked. Such activities can be taken in amateur home conditions, as you know how to disassemble a laptop without damaging it.
    My cousin gave the equipment to the service, which he asked for PLN 1000 for replacing the motherboard, he came to me, although he does not service laptops, he was rescued in this way and has been working for three years. My daughter did the same a year ago. :(
    And now the question is, did you expect such an answer? Contrary to appearances, these are not simple activities, this equipment has to be assembled, it is a very delicate and precise work, time-consuming. ;) If you have never done it, and I think not, and you don't have anyone who knows what it is doing, then, as a colleague wrote above, the website.
  • Possible cooling-system fault and repairability question
    #4 16540458
    Kurczak1234
    I am not going to do it myself, because I have absolutely no idea about such things. I meant more about whether there is a chance to salvage the laptop at all. It seems to me that she had a rather small amount of water in contact with the laptop, and on its bottom, apart from the fan openings, there are no others. I also do not know if it is possible that if now the laptop does not show "any signs of life" then it will suddenly start up after such cleaning. It also seems to me that the computer could have a defect when it comes to the cooling system, because before that, twice, I had a situation where the computer worked properly, and the next day it was impossible to restart it the next day (there were also no signs of life, even while connecting the AC adapter). I then gave it to the service (it was still under warranty) and in the description after the review I saw that the cooling system was only cleaned and nothing else, and the laptop worked fine (after 2 months the story repeated and it was sent to the service again, where they did all action and it worked until the day before yesterday). Thanks for the previous answer
  • #5 16540535
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    It may not be a flooding effect, but a recurring previous fault. If it is under warranty, give it back, do not say anything about flooding, so as not to suggest a response from the website.
  • Warranty expired, but flooding was ruled out
    #6 16540543
    Kurczak1234
    It is no longer under warranty, it expired at the end of March :( Not only that, when I had it serviced earlier (when it was under warranty), after the first inspection, "nice gentleman in the department" informed me that the computer looked flooded .. but I knew that it did not happen and after an in-depth analysis, they found that after all no. But the first suggested answer is the flooding ... I can see that whatever happens they always put the same thing first.
  • #7 16540569
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    No one knows this. But it's probably worth a try.
  • #8 16540628
    Kurczak1234
    It's always worth a try, today I will take the unfortunate man to the site. Thank you again for the information provided :)
A user reported that their ASUS laptop was accidentally flooded from the bottom due to water spilled on the table. After disconnecting the laptop and allowing it to dry for a day, it failed to power on. Responses suggested that water damage could be severe, and recommended professional service for diagnosis and potential cleaning of the motherboard with isopropyl alcohol. Some users noted that previous issues with the laptop might not be related to the flooding. The user confirmed that the warranty had expired, complicating the situation. Ultimately, the user decided to take the laptop to a service center for further evaluation.
