Scooter - Replaced Chopper, Cables, and Bulbs: Indicators Still Not Working, Long & Short Lights
kdzieciol471 870 2
  • #1 21057118
    kdzieciol471
    I have a zipp triad 2, I have replaced the interrupter with a new one but still no turn signals. On the old interrupter they burn with a continuous light. I also replaced the fuse at the battery with a new one. Where can I find the problem
  • #2 21057170
    mariukonie
    Help: 197
    Rate: 379
    Check the new interrupter is in working order.
  • #3 21057192
    pszczyna
    Help: 213
    Rate: 403
    The contacts of the relay or coil may have stuck together, replacing it with a new one should solve the problem, but first check the installation for fractures and the relay is notoriously jammed.
