Play 4G LTE Internet Disconnects Frequently: Experiences with Alcatel LinkZone Modem in Kościerzyna?
Hexi 22935 11
Why does an Alcatel LinkZone on Play 4G LTE keep disconnecting and slowing to zero during downloads, and how can I diagnose it?
The modem is most likely suffering from poor LTE conditions or unstable power, so you need to check the real radio parameters and whether it is rebooting or losing current. Log in to the modem admin page at `http://192.168.0.1` (or `mobile.hotspot`), set the connection mode to auto and the network mode to LTE, then look at the signal details in the Connection tab [#16551258][#16551266] Do not rely on signal bars or RSSI alone, because they do not tell you enough about the LTE signal quality [#16551322] Use LTEWatch_H or a similar tool and report exact values for RSRP, SINR, RSRQ, and RSSI so the connection can be assessed properly [#16714948] Also check the modem power supply, because a reboot caused by insufficient power can look like a network drop [#16551258][#16714948]
  • Frequent LTE disconnects and speed dropping to zero
    #1 16549008
    Hexi
    Rate: 11
    For some time, I started to disconnect the internet in Play.
    Alcatel LinkZone modem
    Play 100GB 4G LTE
    City: Kościerzyna
    Normally, I can not stand it, first when I wanted to download something, for example, updating to Windows 10 it dumped the net and I had to reset the modem or computer.
    Now, even when I enter the net, I hardly came in here, because every now and then the internet disconnects.
    I installed the Autoconnect program, it worked, I downloaded these updates.
    However, after rebooting the computer turns off again.
    I noticed that when downloading, the speed slows slowly to zero.
    I am asking for a quick answer.
    Greetings.
  • #2 16550068
    kiko80
    Help: 67
    Rate: 163
    Nobody here has a crystal ball, start with what your signal strength range is
  • #3 16550468
    Hexi
    Rate: 11
    Now I have one, but at night it was 70download and 12upload ping was also low http://www.speedtest.pl/wynik/151776490
    @ kiko80
  • #4 16550696
    kiko80
    Help: 67
    Rate: 163
    I meant the signal strength, not speed
  • #5 16550712
    Hexi
    Rate: 11
    How should I check?
    Added after 2 [hours] 3 [minutes]:
    Will I find out?
    Added after 36 [seconds]:
    Added after 2 [hours] 25 [minutes]:
    2 days I am waiting for a response, and as I play net it crashes, it terribly teases so please answer
  • #6 16551258
    MrRoger
    Rate: 8
    1. Connect the power supply for the modem and charge it or measure it on the connected power supply.
    2. Open your browser, enter: http://192.168.0.1
    3. password "admin" as long as my memory is correct.
    3a If you have a modem connected directly to your computer, you can log in using the "Web Connection" application
    4. Network setting tab -> Connection Mode - select the car.
    5. "Network mode" tab -> Network Mode - Select LTE (with weaker connections it may charge you Internet fees)
    6. "Connection" tab - it shows the signal strength in "dashes", and after hovering over the RSSI indicator, enter the data.
    Additionally:
    A) Do you connect to WiFi with a modem?
    B) Where is the modem?
    C) What is your band in the place where the mobile phone modem is located (from the same network as the internet / modem)
  • #7 16551264
    Hexi
    Rate: 11
    Additionally:
    1. Yes
    2. By the window, as I give on the window sill, there is a bit better quality but I'm blown away by the internet.
    3. I want to check by going to this page but I'm getting this site unreachable
  • #8 16551266
    MrRoger
    Rate: 8
    Skopiowane z instrukcji:
    Access the Admin Page using Wi-Fi
    Connect to your hotspot device through Wi-Fi using the network connection software on your computer.
    Provide the Wi-Fi network password, if requested.
    Open a browser and enter http://mobile.hotspot or http://192.168.0.1 in the address bar. The Mobile Hotspot login screen appears.
    Enter the Admin Page administrator password. (Default password: admin).
    Select the Save Password checkbox if you wish to bypass the login screen in the future.
    Click Login. If you entered the correct password, the Web User Interface screen appears.
    Access the Admin Page using USB
    Connect your Mobile Hotspot to the PC with USB cable.
    Power on your device. The OS detects and recognizes new hardware and finishes the installation automatically. After successful installation,the web connection icon will appear on your desk.
    If the system does not launch installation automatically, run the installation program in path of My Computer > Mobile Hotspot.
    Double click the icon to open the Admin Page login screen.
  • #10 16552080
    Hexi
    Rate: 11
    matek451 wrote:
    Gentlemen, are you so serious? After all, in the topic of LTE coverage in Play, everything has already been explained https://www.elektroda.pl/rtvforum/topic3335518.html#16443408#16443408 Why would a colleague dashes or RSSI that say nothing about the LTE signal?
    But now it suddenly started to disconnect, maybe you need to buy your own router?
    Added after 8 [hours] 59 [minutes]:
    I do not know what is happening now, the Internet is so slow, I am waiting 10s for loading the site even though I still have 100gb because from time to time I'm walking fast.
  • Heavy downloads trigger minute-long LTE disconnects
    #11 16683698
    vvrona
    I have sad news after the tests I have to say with redbull, I do not know how to play off the Internet for a moment when we load the Internet for a long time, about 5-10 minutes, disconnects for a minute.
    This is mainly the case when downloading files (this can be avoided by downloading some free download program and cutting off the transfer), But just try to download something from the stem, or download the updates and there is already a massacre.
    So when you have a redbull (and you can not play the test), it works for you and then every now and then disconnects the internet, but the router has a range and does not disconnect from the network, do not do it operator flies
  • #12 16714948
    MrRoger
    Rate: 8
    Chick, sorki, I'm reheating the cutlet, but how can they turn you off? They are from this contract, you have a data package, nobody (I think) will cut off from BTS, because how - some machine restarting the mast, server would cut out IP data etc ... ;-)
    Well, without the eggs, give me the details that my friends asked for
    Look on the program's network: ltewatch_h (works with some hujawyers) ;-)
    Provide exact data:
    RSRP
    SINR
    RSRQ
    RSSI
    and make sure you do not get LTE modem, and this 1min is not getting up (reboot) that you have enough "currents" - power on it.
    The more you write, do the tests, we will be able to help you better.
    At home I have such a Creation at home:
    The 5A 12V power supply (I know a madman, but it would not be heated up under the plate), which powers me
    2 fans 12V (one cooling MR3420, the other E3372)
    MR3420 (only as a gateway it can be used without firewalls etc so that it does not sweat)
    5V 2.6A power supply that powers:
    Active HUB
    e3372 HiLink modem
    Between the hub and the MR3420, I soldered a diode on the USB cable, so that in the event of a short circuit or something you did not go on the USB current in the MR3420
    Antenna Sorensen 17 (I think)
    For Internet distribution at home RT-N16
    I am downloading the net from the mast behind the forests, mountains and rivers ;-)
    Only, I'm perverted and I like electronics, I'm buried in it. Maybe someday I will upload photos on the forum.
The discussion revolves around frequent internet disconnections experienced by a user in Kościerzyna while using the Alcatel LinkZone modem with Play's 4G LTE service. The user reports issues such as slow speeds, particularly during downloads, and the need to reset the modem or computer to regain connectivity. Various responses suggest checking signal strength, accessing the modem's admin page for settings adjustments, and ensuring proper power supply to the modem. Some users recommend using a different router or modem to improve stability. The conversation highlights the importance of signal quality and network settings in maintaining a reliable internet connection.
