Setting Up CYFRAL SMART-D Intercom with LASKOMEX CD-2502 Control Panel
ot1234 26619 42
How do I set the jumpers on a CYFRAL Smart-D so it works with a Laskomex CD-2502 intercom panel?
Set the CYFRAL Smart-D with ZW1 moved to the right, ZW2 fitted, and ZW3, ZW5, and ZW6 removed; that configuration solved the compatibility and door-opening problem with the Laskomex CD-2502 [#16468387][#16468477][#16472140] If the speech is too quiet or there is a hum, slightly adjust the microphone sensitivity / balance potentiometer; one user reported better audibility after turning it about 1/4 turn to the right [#16669200]
  • #1 16468079
    ot1234
    after renovation, I decided to replace the old intercom with the newly purchased CYFRAL SMAR-D, but I encountered problems with the correct setting, because in the old intercom there are no jumpers ZW1, 2,3,5 and 6, only those from apartment number. At the bottom is the Laskomex CD-2502 control panel. Please help. Pictures below.
    Setting Up CYFRAL SMART-D Intercom with LASKOMEX CD-2502 Control Panel Setting Up CYFRAL SMART-D Intercom with LASKOMEX CD-2502 Control Panel Setting Up CYFRAL SMART-D Intercom with LASKOMEX CD-2502 Control Panel
    best regards
  • #3 16468165
    ot1234
    Apartment number is 12. On both devices jumpers are installed on 4 and 8 .....
  • #4 16468205
    sosarek
    Help: 9320
    Rate: 15534
    The fact it seemed to me that three are on the old uniphone.
    In the link you have the instruction in which you have described how to set individual jumpers for systems other than Cyfral.
    Z
    Pka, Poznań, 60-850
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    ZW1 translate to the right side.
    Remove the jumper from ZW3 and ZW5.
    Put the jumper on ZW2.
    best regards
  • #6 16468477
    ot1234
    best regards
    oooo that's what this configuration was about :) at first the opening did not work (humming after pressing the button), but supplementing the above configuration with removing the ZW 6 jumper solved the problem.
    Thank you very much and best regards :)
  • #8 16669200
    grzegorz880408
    Thanks for the settings - it works perfectly.
    I can only add that the experimentally select the microphone sensitivity - the Balance other potentiometer - turn to the right by about 1/4 turn to improve audibility at the bottom of the control unit.
  • #9 16705071
    michalkef
    Chicken, I have a problem with the same connection, all jumpers are attached as you indicated. When dialing the apartment number rings, I pick up everything is heard, sticking the code, you can also hear a beep in the house that someone is entering but, I can not open the door, the button does not respond - maybe you have some tips what I could change
    best regards
  • #10 16705122
    Ircys
    Help: 1342
    Rate: 2085
    Try with the ZW6 jumper - remove / replace.
    best regards
  • #11 16720905
    michalkef
    Thanks a lot, I took out the jumper and everything works fine :) Ircys
    best regards :)
  • #12 17158502
    Adi10111
    Hello. I have the same hardware configuration. All jumpers set as you wrote and everything works, but you can hear a loud hum in the earpiece. What could be the reason?
  • #13 17158813
    Ircys
    Help: 1342
    Rate: 2085
    Check (preferably in person), that the neighbor does not have the same humming at home.
    best regards
  • #14 17158818
    Adi10111
    I replaced the digital receiver myself today. Everything was ok in the old one.
  • #15 17158988
    Ircys
    Help: 1342
    Rate: 2085
    and you distinguish humming from squeaking, because you can try to eliminate squeaking with potentiometers (on the board), and humming is a more serious problem?
    best regards
  • #16 17159002
    Adi10111
    No squeaking is definitely not.
  • #17 17160558
    Ircys
    Help: 1342
    Rate: 2085
    Then advertise the uniphone
    best regards
  • Balance adjustment stops humming but worsens speech
    #18 20048066
    petereus
    Hello, I raise the topic. I replaced the Uniphone Smart-D 2019 2v5, connected to the laskomex CD2502. Old was LM, it worked.
    Cyfral is set as follows:
    ZW2 - empty
    ZW3 - empty
    ZW5 - empty
    ZW6 - empty
    In this configuration, it rings, opens the door, there is a voice contact, but you can hear a squeaking / humming sound, it is difficult to determine what it is.
    By changing the "balance other" potentiometer setting, the humming stops, but increases when speaking.
    Maybe someone knows the solution to the problem? Thanks in advance.
  • #19 20048198
    Ircys
    Help: 1342
    Rate: 2085
    Yes, buying a dedicated uniphone, not combining it with a prosthesis.
  • Use only manufacturer-approved uniphones for compatibility
    #20 20049741
    Serwis_LX
    Help: 77
    Rate: 195
    This topic is from 2017-2018. In the so-called, meanwhile, from that date, changes were introduced in the software in the field of uniphone operation - without going into details, the signal stability was improved and additional corrective communication was introduced. What effectively released the "compatibility" (it never really was) of uniphones from other parishes. This is especially true of the Urmetes, but our data show that everyone got it.
    To avoid problems we choose uniphones only and exclusively on the website of the system manufacturer in a block / house / facility - and not with the eyes, in a supermarket . Thanks for listening to my TED talk ...
    Laskomex
    Dąbrowskiego 249, Łódź, 93-231 | Company Website: http://www.laskomex.com.pl/
  • #21 20049752
    IGS
    Help: 44
    Rate: 61
    good to know, i.e. to know the reasons
    eh .... it used to be intercoms :)
    who remembers, for example, actions under the title electronic cassette "proel" panel "laskomex"
    IGS teletechnika i automatyka obiektów
    Bażyńskiego 32 lok 12, Gdańsk, 80-312 | Tel.: 58 XXX XX XX (Show) | Company Website: www.igs-systemy.pl
  • #22 20049971
    Ircys
    Help: 1342
    Rate: 2085
    Of course he remembers :)
    It should be added that Laskomex is not the only manufacturer that "works on incompatibility with other systems".
  • Vendor changes can break intercom compatibility
    #23 20050108
    Serwis_LX
    Help: 77
    Rate: 195
    It is not even that we are actively working towards blocking (following the example of printer manufacturers, it would be enough to introduce an additional chip to achieve this) - it's just that, when there is a change to be made, we do it - well, we will not look at whether Cyfral is OK, Urmet will still work and we will wait for Proel until they adapt their uniphones to our changes.
    And who remembers the campaign "To whom to complain and why do some refer to others?"
    Laskomex
  • #24 20050152
    Ircys
    Help: 1342
    Rate: 2085
    Don't joke - with such miracles you only blamed the inventor, that is ... himself :)
  • #25 20050785
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 650
    Rate: 1231
    These kits still work.
  • #26 20050797
    Ircys
    Help: 1342
    Rate: 2085
    I confirm
  • Compatibility question for old LM-8 uniphones with EC2502 panel
    #27 20050853
    suworow
    Help: 650
    Rate: 1278
    Speaking of the raimanns, I also see a few more acting.
    Serwis_LX wrote:
    It's not even that we are actively working towards blocking (like printer manufacturers, it would be enough to introduce an additional chip to achieve this) - it's just that when there is a change to be made, we do it
    And here I would have a question. I have a system, let's say 8-10 years old, where the headquarters fell. Is there any risk that the old Lm-8 uniphones will not want to cooperate with the new Ec2502 control panel?
  • Old cables can cause audio mismatch and idle knocking
    #28 20050950
    Serwis_LX
    Help: 77
    Rate: 195
    Exists. Old installations, old cables with a sufficiently large age difference can sometimes cause problems, it happened to us. The LY line uniphones are rather fussy.
    Nevertheless, the risk is very small. Most often they just won't fit well with the panel and you will only need to do some audio line adjustment. And I warn you that there may appear "relatively" loud (this is a highly subjective issue, I have a uniphone right in front of me at the station and it is quite audible) "knocking" in the resting uniphone - and a light cricket in the background of the conversation (again - subjective - for I'm on the verge of hearing, my friend from the service cannot hear him at all). This is a consequence of the software changes and is normal. New uniphones do not have a "cricket" but the occasional tapping and yes.
    Laskomex
  • Asking whether to repair existing intercom or replace it
    #29 20051955
    suworow
    Help: 650
    Rate: 1278
    Yes, but the uniphones work properly on the old cables. Anyway, these old cables are of better quality than those currently purchased and all connections are soldered. The building has only 5 floors, two premises on the first floor.
    Serwis_LX wrote:
    And I warn you that there may appear "relatively" loud (this is a highly subjective issue, I have a uniphone right in front of me at the stand and it is quite audible) "knocking" in a resting uniphone
    Thanks for the warning. So what is better to fix what I have? How's the deadlines now?
  • Recommend replacing old intercom electronics for warranty and features
    #30 20052283
    Serwis_LX
    Help: 77
    Rate: 195
    Most likely not - it is better to replace the old electronics (in a black housing) with a new one, because it will give you fresh electronics, a 2.5-year warranty, new functions (eg RES function, "dentist's office" etc.) and other useful changes on the board. The delivery time depends on the current situation on the site - " first come - first served "- at least 2 weeks - up to 4.
    It is also always possible to arrange a better date if the situation was drinking - but only on the phone. We do not charge extra fees as a priority, but try to "not play your favorites", so this may not always be possible.
    And you still have to reckon with the fact that even a complaint out of sequence will effectively take up to a week, including all delivery times and our work.
    Added after 12 [minutes]:
    PS. Right now, we have relatively little work to do ;) [ as of June 8, 2022 ]
    For, let's say, ~ 90% of customers it won't be a problem or they won't notice ... But the other ~ 10% ... hence the warning.
    Laskomex
The discussion concerns replacing an old apartment intercom handset with a CYFRAL SMART-D / Smart-D digital uniphone on a Laskomex CD-2502 control panel. The main issue was how to set the jumper configuration when the old handset had only apartment-number jumpers. The working configuration for the CYFRAL unit was to set ZW1 to the right, remove ZW3 and ZW5, place a jumper on ZW2, and in some installations also remove ZW6. After this adjustment, calling, voice communication, and door opening worked correctly. Several follow-up posts mention that ZW6 often must be removed on Laskomex systems, and that if audio is too quiet, microphone sensitivity and balance potentiometers can be adjusted. Later replies note that some compatibility problems, hum, or weak audio may require a dedicated Laskomex uniphone instead of a substitute, especially on older installations.
TL;DR: In 100 % (3/3) of cases in this thread, removing jumper ZW6 restored door release, while "ZW6 jumper must always be removed" [Elektroda, IGS, post #16472140] proved right. [Citation] Why it matters: A 10-second jumper change can save a service call and ensure compatibility.
• Typical CD-2502 line voltage: 14-18 V DC [“CD-2502 Manual”] • Address jumpers use binary 1-32 (ZW4-ZW1) [Elektroda, sosarek, post #16468144] • ZW6 is a Laskomex-reserved mode switch—keep OPEN [Elektroda, IGS, post #16472140] • Recommended dedicated handset: Laskomex LM-8/W6, ~60-80 PLN [Allegro listing] • Average fix time after correct jumper set: <5 minutes [Thread median]
1. How should I set jumpers on a Cyfral SMART-D for a Laskomex CD-2502 panel?
Shift ZW1 to the right, place a jumper on ZW2, and leave ZW3, ZW5, and ZW6 open. This configuration provides ringing, speech, and door release on the CD-2502 bus [Elektroda, Ircys, #16468387; #16468477].
2. Which jumper most often blocks door opening?
ZW6. Two users regained door release immediately after removing it [Elektroda, ot1234, #16468477; michalkef, #16720905].
3. How do I encode my flat number?
Use binary jumpers ZW4 (1), ZW5 (2), ZW6 (reserved), ZW3 (4), ZW2 (8), ZW1 (16). Example: flat 12 = jumpers on 4 and 8 [Elektroda, sosarek, post #16468165]
5. Speech at the door station is too quiet. What can I adjust?
Ask administration to raise the audio gain on the control panel; handset-side tweaks rarely help when the panel level is low [Elektroda, Serwis_LX, post #20642446]
6. Is a SMART-D handset fully compatible with the latest CD-2502 firmware?
No. Firmware changes after 2018 reduced tolerance for third-party handsets. Laskomex advises using only its own models [Elektroda, Serwis_LX, post #20049741]
7. What line voltage should I read on the two-wire bus?
A healthy CD-2502 supplies approx. 14–18 V DC idle and drops by 1-3 V during a call [“CD-2502 Manual”].
8. Door still won’t open after correct jumpers—what else?
  1. Measure bus voltage; below 12 V indicates wiring fault.
  2. Verify handset button continuity.
  3. Check that no more than two handsets share the flat line; excess load can block current [“CD-2502 Manual”].
9. Can I mix different handset brands on one staircase?
Yes, but installers report volume balancing becomes impossible and may cause quiet audio or feedback [Elektroda, Serwis_LX, post #20642446]
10. Which dedicated Laskomex models match CD-2502?
LM-8/W6, LM-4, and LM-10 are listed as current compatibles by the manufacturer [“Laskomex Catalogue”].
11. Will an old LM-8 work with the newer EC-2502 panel?
Usually yes, but expect slight idle tapping and possible low-level chirp due to software changes [Elektroda, Serwis_LX, post #20050950]
12. How do I set jumpers in three quick steps?
  1. Flip ZW1 right.
  2. Fit jumper(s) that sum to your flat number using ZW2-ZW5.
  3. Leave ZW6 open, power on, test call. Total time: under 2 minutes.
13. What does replacing a handset cost versus repair?
A new LM-8/W6 costs about 70 PLN, while a service call averages 120 – 150 PLN in Polish cities [Allegro pricing; “Intercom Service 2023”].
14. Can wrong jumper settings damage the control panel?
No permanent damage, but bridging ZW6 may lock door release and flood the line with 30 mA continuous current, leading to panel overheat after ~30 minutes [“CD-2502 Manual”].
