[Solved] Xbox 360 Parental Control Code: Hard Factory Reset for Converted Consoles & Solutions
ziguś 10161 8
  • #1 16563245
    ziguś
    Rate: 269
    I bought an xbox for my son some time ago. Until now everything worked Ok, a problem suddenly appeared, the console asks for the parental control code. I suppose the boy had fun and unwittingly founded it because there is no other explanation. I formatted the hard disk and tried different ways from the internet but none work. I bought the Xbox as "converted" so that it read the CDs that were being played.
    Is there a way to do a hard factory reset?
  • #3 16593049
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Hello, There is no standard code for all consoles, go to console settings, general and then system data and enter serial number.
    Best Regards
    Console service
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • #4 16593119
    ziguś
    Rate: 269
    I drove to a guy who does such things, problem solved
  • #5 16689981
    Rev_krk
    Rate: 16
    This can be done in 2 ways:
    1 - we extract the contents of nand and read the master key
    2 - we are looking for a master key by trial and error, all masterkey listed can be found on the Internet.
  • #6 16690327
    ziguś
    Rate: 269
    And how do we "extract the contents of nand and read the master key"?
  • #7 16869285
    tomi26
    Rate: 17
    I will not post a new topic because my problem is identical to the colleague who assumed this topic. I wrote to Microsoft and they do not give me the ready code to paste, they just write something about console registration etc. I register the console on their website, at the beginning it is added to the account as a device, in a moment this governance is gone: / massacre.
    Is there any other proven way to turn this damn thing off?
  • #8 16936790
    Dzaro5
    Rate: 20
    Just as colleagues wrote the trial and error method above, or draw nand put RGB and read what is the combination to reset. Sometimes I get these to unlock.
    And as for Microsoft, it is so that you must have an account from which you report the problem to support.
  • #9 17209175
    ziguś
    Rate: 269
    I gave it to someone who deals with it on a regular basis
The discussion revolves around resolving a parental control code issue on a converted Xbox 360 console. The user, after formatting the hard disk, seeks a method for a hard factory reset due to the inability to recall the parental control code, which may have been inadvertently set by their child. Various solutions are proposed, including extracting the NAND contents to read the master key, using trial and error to find the master key, and contacting Microsoft for support. Some users suggest seeking professional help for unlocking the console, as Microsoft does not provide direct codes for resetting parental controls.
