Recommended Hydraulic Oil for Ravaglioli RAV516NL Scissor Lift: L-HL32, ESSO NUTO H32, Winter Use
ekspertauto 12534 4
  • #1 16563314
    ekspertauto
    I am not a specialist when it comes to hydraulic oils and I would like to know what hydraulic oil would be suitable for my scissor lift.
    The lift is Ravaglioli RAV516NL according to the instructions unless it should be ESSO NUTO H32 oil or equivalent.
    From what I learned, 32 is viscosity / density and the letter before is a quality class.
    Can I buy L-HL32 oil or will it be good? What do you recommend about which sign?
    Does oil color matter? I heard that they are dyed e.g. red and normally it is straw.
    The lift is standing in a hall where in winter the temperature drops to 0 degrees and I do not know whether to look at this quality class or just important to be 32.
    I would ask for help if a topic set up in the wrong department would ask a moderator to move.
    Regards.
  • #2 16563355
    bearq
    Help: 414
    Rate: 1612
    Flood HL 32 and it will be ok, with denser there may be a problem with lifting.
  • #3 16563377
    ekspertauto
    Please tell me if L-HL32 is something different from HL32?
    in the automotive wholesaler I can buy L-HL32 I don't know much about hydraulic oils, I was looking for but I didn't find much about it. I would like to know if it will work and whether nothing bad will happen.
  • #4 16563383
    bearq
    Help: 414
    Rate: 1612
    No, L-HL32 is the full name.
