Cyfrowy Polsat TV Signal Loss After Storm - Converter & Cable Replacement Ineffective, Dish Damage?
lukasz2090 12864 14
Why did my Cyfrowy Polsat satellite signal disappear after a storm even after replacing the converter and cable, and could the dish be damaged?
Yes — if the decoder works with another dish and replacing the converter/LNB and cable made no difference, the remaining likely cause is the antenna setup itself, including possible hidden dish or bracket damage from the storm [#16563754][#16563775][#16563780][#16563789] Even a small misalignment can cause a large signal drop in digital TV, and the LNB rotation also matters [#16563795] The practical next step is to check the signal level with a meter/tester and realign the dish for the best signal [#16563795] If you do not have measuring equipment or experience, call someone who does [#16567126]
  • #1 16563747
    lukasz2090
    I warmly welcome. I have Tv from Cyfrowy Polsat. After the storm, the signal disappeared. I thought it was the converter's fault so I exchanged it but it did not work. To be sure, I also checked the second converter and nothing. The cable connected to the New and also to no avail. Is it possible that it will damage Czasza? After all, it has not been bent etc. I am asking for a hint.
    I will add that the decoder is 100 per cent effective because I connected to the second satellite dish (another household member) And it's ok.
  • #2 16563754
    andpol 33
    Help: 513
    Rate: 1145
    Since everything is checked, only the antenna setting remains.
  • #3 16563765
    lukasz2090
    The canopy itself was not checked. I do not know if it's possible to get damaged
  • #4 16563769
    andpol 33
    Help: 513
    Rate: 1145
    It shows on the eye that it is not creased.
  • #5 16563775
    Maciek051996
    Help: 99
    Rate: 300
    If the conversion of the converter and the cable did not work, try to borrow the whole decoder from someone. It is possible that the storm was damaged.
    3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
  • #6 16563779
    lukasz2090
    The decoder is operational. It was changed. The only question is whether it is possible that somehow Czasza has damaged after the storm. There is no mark in the form of dents. Everything else was checked.
  • #7 16563780
    Lomax33
    Help: 13
    Rate: 26
    A colleague wrote that the decoder works on a different antenna 100%.
    You are left with your antenna setting with the signal level meter. Probably during the storm the bowl was broken and therefore no signal
  • #8 16563787
    lukasz2090
    The chicken was permanently attached. Mega tight.
  • #9 16563789
    andpol 33
    Help: 513
    Rate: 1145
    After the recent storms, even the handles were bent as the antenna would not give up.
  • #10 16563790
    lukasz2090
    Well, I will combine. I have no idea how it sets up. I've heard about some android programs but I do not know how to use it
  • #11 16563795
    Lomax33
    Help: 13
    Rate: 26
    You will not find out for your friend. You need to connect the meter and check the signal level. Even a slight violation of the antenna at the digital signal causes a large drop in the signal. Even twisting the converter is important, as I write. Connect the meter and set to get the best signal from the antenna
    Just such a small miracle for PLN 25 (the cost is negligible) and miracles work Cyfrowy Polsat TV Signal Loss After Storm - Converter & Cable Replacement Ineffective, Dish Damage?
  • #12 16563810
    andpol 33
    Help: 513
    Rate: 1145
    It is not a meter. Laika can not handle it.
  • #13 16563822
    Lomax33
    Help: 13
    Rate: 26
    Well, "tester". I used the colloquial name that is used in my region :)
    I do not know. The instructions are read with understanding, everyone knows how to learn everything step by step. Take some patience and give advice :)
  • #14 16564256
    LeDy
    Help: 1990
    Rate: 2933
    Step by step, he was doing it and what came out of it? Substitute several converters, wire and look for bowl damage? Now everything can be like an amateur, he puts them together and put them together.
    I would advise someone who is familiar and not recommend the indicator. :D
  • #15 16567126
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Exactly, instead of buying new elements of the antenna set, it was necessary to call someone who has knowledge and measuring equipment.
After a storm, a user experienced a loss of TV signal with their Cyfrowy Polsat setup. They replaced the converter and checked the cables, but the issue persisted. The decoder was confirmed to be functional with another dish. Suggestions included checking the antenna alignment and using a signal level meter to diagnose potential damage to the dish (Czasza) or misalignment due to the storm. Some users noted that even minor adjustments to the antenna can significantly affect signal quality. It was advised to consult a professional with the necessary measuring equipment for accurate troubleshooting.
