TL;DR: 77 °C equals 87 % of GTX 970’s 90 °C ceiling; "80 °C is nothing for the GPU"[Elektroda, safbot1st, post #16568652] Log temps, limit FPS, check CPU load—these steps solve most sudden 140→60 FPS drops. Why it matters: Small tweaks prevent throttling, stutter and premature card wear.
• GTX 970 TDP: 145 W [NVIDIA Spec].
• GPU Boost begins lowering clocks ≈80 °C [TechPowerUp, 2015].
• Max-safe temp reported by NVIDIA: 98 °C [NVIDIA Spec].
• Recommended PSU for GTX 970 system: ≥500 W [RealHardTechX, 2023].
• Corsair VS550 delivers 42 A on +12 V rail (504 W) [Corsair Datasheet].
Is 77 °C dangerous for an MSI GTX 970?
No. GTX 970 cards are rated up to 98 °C; Boost 2.0 starts down-clocking around 80 °C, so 77 °C is below the throttle point and 21 °C under the limit [NVIDIA Spec][TechPowerUp, 2015]. Forum users agree that 77 °C "shouldn’t bother you"
[Elektroda, JasnyKris, post #16568136]
Why does GPU usage sit at 100 % during demanding games?
What causes FPS to plunge from 140 to 60?
How do I identify rogue CPU processes while gaming?
- Open Process Explorer.
- View → Select Columns → Process Performance → CPU History.
- Alt-Tab when stutter appears and sort by CPU %. Screenshot the window for later review [Elektroda, Kasek21, post #16568261]
How can I log temperatures and FPS together?
Run HWiNFO64 in “Sensors-only” mode, tick “Log All Sensors”, then launch FRAPS for FPS overlay. Play 10–20 min, stop logging, and inspect the CSV graphs
[Elektroda, Kasek21, post #16568169]
Could the Corsair VS550 be the culprit?
Possibly. The VS550 meets power requirements on paper (504 W on +12 V) but ageing capacitors can droop under load, producing lag spikes or crashes [Corsair Datasheet]. Checking +12 V ripple with a multimeter per the Elektroda guide helps rule this out
Should I disable the factory overclock (OC)?
Yes, for troubleshooting. Lower core clock by 100 MHz or hit “Reset” in MSI Afterburner. A stable base clock removes OC-related instabilities without permanent changes
[Elektroda, safbot1st, post #16568348]
How often should I replace GPU thermal paste?
Which airflow tweaks give the biggest temperature drop?
Clear front intakes, add one intake and one exhaust 120 mm fan, and keep cables off the GPU path. Users report 5–10 °C lower GPU temps after removing the case side panel
[Elektroda, Stakenxd1, post #16568221]
Why does enabling V-Sync help?
V-Sync caps frame output to the monitor’s refresh, cutting redundant rendering. In the thread, GPU load fell from 100 % to ~70 % with V-Sync on, smoothing frame-time variance
[Elektroda, Stakenxd1, post #16569058]
What CPU temperature is safe for an i5-4690?
Intel specifies a TJmax of 100 °C; practical gaming targets stay below 75 °C to avoid long-term silicon stress [Intel Ark].
What happens if a GTX 970 exceeds 95 °C?
The card reduces voltage and clock speed, drops FPS, and may shut down to prevent VRM damage. Thermal runaway can permanently weaken the GPU’s solder bumps—a rare but documented failure mode [NVIDIA Whitepaper, 2016].
How do I reset all custom settings in NVIDIA Control Panel?
