Problem with Hot Bird 6/8/9 Satellite Setup - Signal Strength & HD5000 Decoder Reset in Germany
Grubasek10928 36408 10
How do I get Hot Bird 6/8/9 reception back on my HD5000 receiver after a reset, when all satellites now show no signal?
You need to realign the antenna/dish again; the receiver reset is not what determines the satellite signal. The decoder parameters do not bring in the signal, so leave them alone and point the dish in the correct Hot Bird direction—in Germany, about 6 degrees to the right when standing behind the antenna [#16914531] If you only had strength/quality before, you likely were not actually on Hot Bird, because transponder parameters are repeated on several satellites and the wrong one can look similar [#16941876] Rotate the dish until both strength and quality appear, then run the channel search again [#16914876]
  • #1 16913049
    Grubasek10928
    Hello!
    As in the subject I have a problem with setting the satellite on hot bird 6/8/9.
    The problem lies in this and I managed to set it and there was a signal strength of 69% and 50% quality so much that it was not able to install programs (it says there is no signal despite the signal was) so I decided to reset the decoder to the default settings and now I can not set satellites back to the one on which was signal, I have to choose satellites such as 13.0E hot bird, 19.2E Astra, 4.8E Astra4, 9E Eutelsat 9, 0.8W Thor, 7.8E Eutelsat 7, 28.2E Astra2, 4.0W Amos, 16.0E Eutelsat 16 and on none of them shows any signal strength. I also tried to set the antenna on 13.0E hot bird but I did not find the signal. I live in Germany near Dusseldorf.
    So my question is, can I somehow come back to this satellite hot bird 6/8/9 or do I have to set the antenna again?
    The decoder has a HD5000 digital video
    Frequency set to 11158 Symbol Rate 27500 Vertical polarization FEC Automatic
  • #2 16914531
  • #3 16914876
    LeDy
    Help: 1992
    Rate: 2940
    So spin the canopy until you show strength and quality and then search.
  • #4 16941876
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Grubasek10928 wrote:
    I managed to set it up and there was a signal strength of 69% and 50% quality so much that it was not possible to install programs (it was said that there was no signal despite the signal was
    No - you did not set anything.
    Every few satellites the transponder parameters are repeated - what you hit was not HotBird.
  • #5 16964228
    metiuesp
    Rate: 8
    I encountered a similar problem. I live in Spain in Valencia. And I tried to set the antenna myself on Hotbird 13. But the decoder does not catch the signal. A trip to a friend who has an antenna set up on the Hotbird, I connected the decoder and also does not catch the signal.
    HD6000 digital decoder polsat.
  • #6 16964317
    KOCUREK1970
    Help: 3862
    Rate: 5490
    metiuesp wrote:
    but the decoder does not catch the signal.
    No decoder only the antenna receives the signal.
    An ordinary 60 cm antenna can be too small there.
    • EUTELSAT_SATELLITE_E13E.pdf (3.29 MB) You must be logged in to download this attachment.
  • #7 16964414
    metiuesp
    Rate: 8
    Yes, I understand. So it's better to have a bigger antenna? At 60 cm on a colleague he receives the range from Hotbird. And with him I connected the decoder and there was no signal either, 0%.
  • #8 16964461
    KOCUREK1970
    Help: 3862
    Rate: 5490
    A colleague what is the antenna there?
    Perhaps your decoder is damaged, or your colleague's other configuration of his antenna.
  • #9 16965669
    metiuesp
    Rate: 8
    A colleague has an ordinary 60. The decoder is new and tested in poland and works. Maybe his antenna is not well set, I do not know, I will try.
    I only have a question, if we set the antenna on the Hotbird, this signal is only one or can it be that you need to better set the antenna? Because like a friend on a normal set-top box, he has a signal and on this from a digital polysat he shows that there is no signal.
  • #10 16965745
    KOCUREK1970
    Help: 3862
    Rate: 5490
    The antenna must be set precisely, preferably using a meter.
    And what equipment does this colleague have, what does he receive, what is this "normal" decoder?
  • #11 16967977
    metiuesp
    Rate: 8
    The antenna was set up without a meter but it does not pick up channels too well, everything works without a problem, you only have to tune the signal. Thank you for your help, I already thought something with the set-up happened. Greetings.
The discussion revolves around issues with setting up the Hot Bird 6/8/9 satellites using an HD5000 decoder in Germany. The user initially achieved a signal strength of 69% but faced difficulties in program installation due to low quality. After resetting the decoder, they could not regain the signal on any satellites, including Hot Bird. Responses suggest that the problem may lie in the antenna setup rather than the decoder itself, emphasizing the importance of precise antenna alignment and potentially using a larger antenna for better signal reception. Users shared similar experiences, indicating that the antenna's size and configuration are critical for successful satellite signal acquisition.
