[Solved] Windows 7 Extended Boot Time despite Windows Update (WU) Being Turned Off
kingpc 4728 13
Why is Windows 7 still taking a very long time to boot even though Windows Update is turned off, and what should I check first?
Windows Update being turned off is probably not the cause; you can leave it off if everything is already installed [#16579512] The first things to check are the disk and startup load: one reply says the drive looks bad, points to SMART parameters C4 and BF, and recommends a surface scan with MHDD [#16579870] The discussion also suggests uninstalling unnecessary software such as Driver Booster and Smart File Advisor and disabling extra startup items in msconfig [#16578831][#16578822] If it is a laptop, the hard drive may simply be the bottleneck, and replacing it with an SSD can make a huge difference [#16579420][#16578822] The thread later confirms that the disk was the real problem [#17022714]
  • #1 16578768
    kingpc
    Windows has been running for a very long time. In addition, WU is off.
    • Shortcut.txt (39.99 KB) You must be logged in to download this attachment.
    • FRST.txt (43.22 KB) You must be logged in to download this attachment.
    • Addition.txt (38.54 KB) You must be logged in to download this attachment.
  • #2 16578822
    bialydam
    Rate: 8
    Disable unnecessary programs in msconfig. I was really helped by changing to a solid state drive, a colossal difference :)
  • Remove Driver Booster and Smart File Advisor
    #3 16578831
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Odinstaluj:
    Smart File Advisor 1.1.8
    Driver Booster
    Wykonaj Fixlist.txt dla FRST:
    Task: {3978BA5D-F94A-4DDE-BDAB-2F9BD2F10CB0} - System32\Tasks\Driver Booster SkipUAC (DOM) => C:\Program Files (x86)\IObit\Driver Booster\4.4.0\DriverBooster.exe [2017-05-03] (IObit)
    Task: {EA274FE3-F69D-4C13-A1F1-345569ECD714} - System32\Tasks\Driver Booster Scheduler => C:\Program Files (x86)\IObit\Driver Booster\4.4.0\Scheduler.exe [2017-03-28] (IObit)
    ShortcutWithArgument: C:\Users\DOM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer (64-bit).lnk -> C:\Program Files\Internet Explorer\iexplore.exe (Microsoft Corporation) -> hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\Users\DOM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer.lnk -> C:\Program Files (x86)\Internet Explorer\iexplore.exe (Microsoft Corporation) -> hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\Users\DOM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories\System Tools\Internet Explorer (No Add-ons).lnk -> C:\Program Files (x86)\Internet Explorer\iexplore.exe (Microsoft Corporation) -> hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\Users\DOM\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk -> C:\Program Files (x86)\Internet Explorer\iexplore.exe (Microsoft Corporation) -> hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\Users\DOM\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\StartMenu\Internet Explorer.lnk -> C:\Program Files (x86)\Internet Explorer\iexplore.exe (Microsoft Corporation) -> hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avast SafeZone Browser.lnk -> C:\Program Files\AVAST Software\SZBrowser\launcher.exe (Avast Software) -> hxxp://www.yoursites123.com/?type=sc&ts=1451317454&z=df3ca673a64284759e1e611g8zdwegdcagfmezbzbb&from=wpm12253&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    ShortcutWithArgument: C:\Users\Public\Desktop\Avast SafeZone Browser.lnk -> C:\Program Files\AVAST Software\SZBrowser\launcher.exe (Avast Software) -> hxxp://www.yoursites123.com/?type=sc&ts=1451317454&z=df3ca673a64284759e1e611g8zdwegdcagfmezbzbb&from=wpm12253&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    (IObit) C:\Program Files (x86)\IObit\Driver Booster\4.4.0\Scheduler.exe
    HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Ograniczenia DefaultScope {33BB0A4E-99AF-4226-BDF6-49120163DE86} URL = hxxp://www.yoursites123.com/web/?type=ds&ts=1449870783&z=6c120e8cac875298bd52a02g5z7z4tebbm0ecmab2o&from=ient07021&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&q={searchTerms}
    SearchScopes: HKLM -> {33BB0A4E-99AF-4226-BDF6-49120163DE86} URL = hxxp://www.yoursites123.com/web/?type=ds&ts=1449870783&z=6c120e8cac875298bd52a02g5z7z4tebbm0ecmab2o&from=ient07021&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&q={searchTerms}
    SearchScopes: HKLM-x32 -> DefaultScope {33BB0A4E-99AF-4226-BDF6-49120163DE86} URL = hxxp://www.yoursites123.com/web/?type=ds&ts=1449870783&z=6c120e8cac875298bd52a02g5z7z4tebbm0ecmab2o&from=ient07021&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&q={searchTerms}
    SearchScopes: HKLM-x32 -> {33BB0A4E-99AF-4226-BDF6-49120163DE86} URL = hxxp://www.yoursites123.com/web/?type=ds&ts=1449870783&z=6c120e8cac875298bd52a02g5z7z4tebbm0ecmab2o&from=ient07021&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&q={searchTerms}
    SearchScopes: HKU\S-1-5-21-3299813100-3397773330-3685223686-1000 -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxp://www.istartsurf.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&ts=1439405688&type=default&q={searchTerms}
    SearchScopes: HKU\S-1-5-21-3299813100-3397773330-3685223686-1000 -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxp://www.istartsurf.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&ts=1439405688&type=default&q={searchTerms}
    SearchScopes: HKU\S-1-5-21-3299813100-3397773330-3685223686-1000 -> {2023ECEC-E06A-4372-A1C7-0B49F9E0FFF0} URL = hxxp://www.istartsurf.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&ts=1439405688&type=default&q={searchTerms}
    SearchScopes: HKU\S-1-5-21-3299813100-3397773330-3685223686-1000 -> {33BB0A4E-99AF-4226-BDF6-49120163DE86} URL = hxxp://www.omniboxes.com/web/?type=ds&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&q={searchTerms}
    SearchScopes: HKU\S-1-5-21-3299813100-3397773330-3685223686-1000 -> {E733165D-CBCF-4FDA-883E-ADEF965B476C} URL = hxxp://www.istartsurf.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS&ts=1439405688&type=default&q={searchTerms}
    StartMenuInternet: IEXPLORE.EXE - C:\Program Files (x86)\Internet Explorer\iexplore.exe hxxp://www.omniboxes.com/?type=sc&ts=1448354998&z=e50b19d8d40aab2ca5cc38cg6z3zcbdc3wcz6tft8b&from=ient07031&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    CHR HomePage: Default -> hxxp://www.yoursites123.com/?type=hp&ts=1449870783&z=6c120e8cac875298bd52a02g5z7z4tebbm0ecmab2o&from=ient07021&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS
    CHR StartupUrls: Default -> "hxxp://www.yoursites123.com/?type=hp&ts=1449870783&z=6c120e8cac875298bd52a02g5z7z4tebbm0ecmab2o&from=ient07021&uid=ST9500325AS_S2WQAXQSXXXXS2WQAXQS"
    CHR HKLM-x32\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
    CHR HKLM-x32\...\Chrome\Extension: [eofcbnmajmjmplflapaojjnihcjkigck] - hxxps://clients2.google.com/service/update2/crx
    CHR HKLM-x32\...\Chrome\Extension: [gomekmidlodglbbmalcneegieacbdmki] - C:\Program Files\AVAST Software\Avast\WebRep\Chrome\aswWebRepChrome.crx
    S3 TDKLIB; C:\Users\DOM\AppData\Local\Temp\TdkLib64.sys [19336 2017-06-28] ()
  • #4 16578944
    kingpc
    Windows 7 Extended Boot Time despite Windows Update (WU) Being Turned Off Windows 7 Extended Boot Time despite Windows Update (WU) Being Turned Off Windows 7 Extended Boot Time despite Windows Update (WU) Being Turned Off Windows 7 Extended Boot Time despite Windows Update (WU) Being Turned Off
    WU turn on?
  • #5 16579420
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Is this computer a laptop?
    If not, think about replacing the disk with an SSD and leave it as storage.
  • #6 16579455
    kingpc
    This is a Lenovo laptop. What about this Windows Update?
  • #7 16579491
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    I do not know, and what should be? You wrote that WU is off.
  • #8 16579500
    kingpc
    WU I have disabled (does not download updates). Is it better to leave or enable?
  • #9 16579512
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    You can leave it turned off if you already have everything installed.
  • #10 16579870
    RADU23
    Help: 2428
    Rate: 1732
    There is something wrong with this disc.
    Please look at parameter (C4).
    In addition, it can be seen that there are falls / impacts (BF).
    @kingpc
    Perform a surface scan with sector access times using MHDD and post a photo =>
    http://www.nirvanowiec.republika.pl/MHDD.html
  • #11 16580081
    kingpc
    I downloaded the update and an error occurred during installation:
    From 1.5 hours now it hangs on the screen with the message "Failed to configure Windows updates. Rollback. Do not turn off the computer"
    What to do?
  • #12 16580119
    Robert B
    Help: 2027
    Rate: 1412
    kingpc wrote:
    I downloaded updates
    For what? Before scanning the disk he was talking about @ RADU23 you did something pointless.
    Windows might also fail to start now. The second time, follow the instructions and do not mix it your way.
  • Hard reset may be needed after update rollback hangs
    #13 16580131
    RADU23
    Help: 2428
    Rate: 1732
    What to do?
    It remains to wait until the changes are rolled back.
    When it hangs for a long time, unfortunately, all that remains is a "hard reset" (not recommended but you won't have a choice).
    What will happen after this and whether the system will stand up, lottery.
    As I mentioned in the above post, first the disk case and then the rest.
  • #14 17022714
    kingpc
    The disk turned out to be a problem
The discussion revolves around a Windows 7 system experiencing extended boot times despite Windows Update (WU) being disabled. Users suggest various troubleshooting steps, including disabling unnecessary startup programs via msconfig and considering a switch to a solid-state drive (SSD) for improved performance. There are concerns about potential disk issues, with recommendations to perform a surface scan using MHDD to check for errors. The conversation also touches on the implications of enabling or disabling WU, with some users suggesting it can remain off if all necessary updates are installed. A user reports an error during a Windows update installation, leading to a rollback, which raises further concerns about the disk's health.
