Cordless Drill Driver Comparison: Bosch GSB 180-LI vs Makita DF457DWE for DIY Tasks under PLN 600
HeksoN 49245 47
Which cordless drill driver is better for occasional DIY, wood drilling, and screw driving within PLN 600: Bosch GSB 180-LI or Makita DF457DWE?
The thread leans toward the Makita DF457DWE for amateur DIY use, while the Bosch GSB 180-LI is treated as the weaker green-line Bosch; Bosch may have a bit more torque and a larger battery, but Makita is praised more for workmanship, balance, and overall suitability for a home user [#16593855][#16593994][#16597022] Several replies also say the battery is the main weak point of any cordless screwdriver and recommend choosing a model with a 3-year battery warranty [#16593858] If you can consider alternatives, users also mention DeWALT, Metabo, Hitachi, Ryobi, Milwaukee, AEG, Parkside, MacAllister, or even a corded screwdriver for very occasional use [#16593994][#16595276][#16597022]
  • #31 16597189
    E8600
    Help: 529
    Rate: 2520
    Zbigniew 400 wrote:
    Xray, I wonder how long these links of yours have been coming from.
    Exactly the 18650 link can be purchased for PLN 8 new and there are also those that cost more than PLN 50. The higher shelf has an additional number of safeguards, e.g. when the drill is blocked in metal, it can cut off the momentary seeding only so that the cells do not get hurt in the butt, giving off a very high short-circuit current. The second issue of durability is the charger, which, despite fast charging, does not damage the cells, shortening their lifetime.
    By the way, these "free 18650 cells" are even suitable for powetbank, not to mention screwdrivers, unless for a small battery screwdriver with a small current. Regeneration of screwdriver batteries is not cheap, as some people think, but it is profitable because, depending on the brand, it costs 50-70% of a new battery.
    One more question of parameters, I personally do not trust the Nm numbers with the cell capacity nowadays, there are also different reviews on the Internet, the original 2.0Ah battery and inside the 1.3Ah cell there are also reverse situations, I write less than I really saw something like this, probably in the metabo or makita.
  • #32 16597215
    Zbigniew 400
    Help: 283
    Rate: 794
    Read more about permissible currents.
  • #33 16597220
    elektronik999
    Help: 8
    Rate: 85
    How are you going to use it sporadically, maybe consider buying a power cordless screwdriver? I use the screwdriver so rarely that when I needed it, it was always discharged, so I switched to 230V.
  • #34 16597397
    leotdipl
    Help: 51
    Rate: 153
    HeksoN wrote:
    Hello, I am looking for a drill / screwdriver (cordless) for up to PLN 600. It will be used for smaller DIY jobs, wood drilling and, of course, driving and removing screws / bolts. I care about the solid performance of the product and the possibility of using it for years. So far, I have selected 2 models, I will be grateful for your help and, of course, I am open to suggestions. Regards
    1. http://www.narzedzia.pl/wiertarko-wkretarka-z-udarem-bosch-gsb-180-li,64850.html [Bosch GSB 180-LI]
    2. http://www.narzedzia.pl/wiertarko-wkretarka-makita-df457dwe,58402.html [Makita DF457DWE]
    I had this Makita in my hands - I would choose her if you were!
  • Recommend a 230V screwdriver for infrequent use
    #35 16597936
    ^ToM^
    Help: 495
    Rate: 2939
    I did the same. I have a B&D screwdriver and I rarely use it, so the battery is worn out after 2 years, even though it is periodically charged and discharged. Every two years I have to buy a set of cells for it.
    So some time ago, I bought a SKIL power screwdriver in Castorama for about PLN 130. Since then, the problems with the screwdriver at home have not existed. Always ready to go. Incomparably high power in relation to cordless screwdrivers (it can twist the hand when holding too weakly) at this price. It turns out SKIL makes decent tools. So, maybe instead of replacing the battery with a new one from time to time, it will be cheaper to buy a power screwdriver at the price of the battery or half the price of a new battery :)
  • #36 16597982
    WędkarzStoLica
    Help: 146
    Rate: 300
    tomiok wrote:
    although it is known that now every manufacturer does so that the tools do not last forever, because it is not profitable for him
    It would be a strange approach :D Each customer who drops the equipment will not return to the brand, and will not recommend it to anyone.
    I don't see the point here.
    For occasional work at home, a screwdriver from Allegro for PLN 200 is enough.
  • Recommend a corded screwdriver for occasional use
    #37 16598109
    LightOfWinter
    Help: 369
    Rate: 935
    If you want a screwdriver for occasional work and for years - I recommend a power screwdriver.
    Batteries used rarely will die, regardless of the company.
    And so you have no batteries and you have peace of mind. In addition, the screwdriver is always ready to work.
    I have been using it for over 3 years and I am satisfied.
    I use it sporadically for small jobs.
    Link
    It is Chinese branded and sold by a company from Rzeszów.
  • #38 16602559
    tomiok
    Help: 133
    Rate: 292
    xray81 wrote:
    I watched for 10 minutes, and ... Bosch was the first to finish screwing.
    Unfortunately, I did not watch the whole thing because there is no time.
    As @LightOfWinter writes, it's worth having such a network.
    I also have an ordinary Chinese (I gave something about PLN 70), and when I do something on site at home, I often use it to save batteries in other screwdrivers. :)
    It works surprisingly, although the warranty has probably expired.
  • #39 16603384
    xray81
    Help: 37
    Rate: 73
    Look again, Bosch finished third after Milwaukee and Panasonic.
  • #40 16604641
    tomiok
    Help: 133
    Rate: 292
    But you can see how he evidently corrects his previously untightened screws?
    This is his fault - not screwdrivers, according to it is biased for me.
    Without it - Bosch wins.
  • #41 17072619
  • #42 17331716
    monia1j
    Hello, I am looking for a gift for my husband a cordless screwdriver (I do not want a power cord), amateur work, tighten the screws at home or something next to the car or motorcycle from time to time. I do not want to buy a poor-quality one, which is about to break down because we already have one and my husband is not satisfied with it. The money I want to spend is up to PLN 500. Please help :)
  • #43 17331888
    E8600
    Help: 529
    Rate: 2520
    Let your friend look for equipment whose manufacturer offers a 3-year warranty on batteries.
    Personally, I would choose between SPARKY and Metabo with a predominance of the former.
    On alledrogo I saw a SPARKY SET SCREWDRIVER IMPACT WRENCH Li-ion 145Nm for PLN 600 and the last piece was left. It is a brand so niche and not very popular that if you look well you can find it even cheaper. In my opinion, it's worth it because we have 2 tools, a screwdriver and an impact wrench (very useful for a car) and 2 14V li-ion batteries.
  • #44 17340801
    jacekRCA
    Help: 14
    Rate: 35
    For a small amount of money you can buy something from ryobi, you will certainly fit in PLN 500, you can consider a model with a brushless motor, it will certainly be more durable and will last longer such equipment
  • #45 17341311
    Zbigniew 400
    Help: 283
    Rate: 794
    Only in case of failure of the basket control.
  • #46 17386821
  • #47 17386837
    Zbigniew 400
    Help: 283
    Rate: 794
    And what breaks in classic screwdrivers?
    What if the electronics fail in the brushless?
  • #48 17395383
    sebastianp88
    Hello everyone, I would like to ask you for help choosing a cordless drill, I am thinking about two models from DeWalt
    https://www.ceneo.pl/53266957;0284-0.htm#tab=click_scroll
    https://www.ceneo.pl/53266950
    the PLN 740 is the maximum budget
    which one would you choose?
    these are similar designs with brushless motor
    one is with stroke the other is without
    now the question is is it worth paying extra for this stroke? it will not increase the risk of failure, if it will be used hard, it's hard to say, maybe it will be useful a few times
    in general, the device will be used for domestic work.
    And one more, if I take a stroke, should the bits also be impact, even though the stroke will be rarely used?
    and if I choose without a stroke, is it worth buying impact bits? or better ordinary
    thank you for helping everyone
The discussion centers around the comparison of two cordless drill drivers, the Bosch GSB 180-LI and the Makita DF457DWE, for DIY tasks under PLN 600. Users express mixed opinions on both models, with some recommending Bosch for its torque and battery capacity, while others criticize its recent quality decline. The Makita is praised for its durability and balanced design, making it suitable for amateur use. Several participants suggest considering alternative brands like Hitachi, Dewalt, Metabo, and Sparky, emphasizing the importance of battery quality and warranty. Users also mention the viability of cheaper options from Lidl and Biedronka for occasional use, highlighting the trend of lower quality in newer models across brands. Overall, the consensus leans towards the Makita for its reliability in DIY tasks, although some users advocate for exploring other brands and models.
TL;DR: 18 V DIY drill-drivers deliver about 50 Nm on average, yet “buy only the blue Bosch line” [Elektroda, tomiok, post #16593994] Li-ion packs can lose 20 % capacity after 500 full cycles [BatteryUniversity, 2023]. Why it matters: picking the right platform saves money on batteries, not just tools.
• Bosch GSB 180-LI: 18 V, 54 Nm, 2×1.5 Ah; PLN ≈550 [Bosch Spec Sheet]
• Makita DF457DWE: 18 V, 42 Nm, 2×1.3 Ah; PLN ≈590 [Makita Catalog]
• Lidl Parkside PABS 20-Li: 20 V, 45 Nm, 2 Ah; PLN 299, 3-year warranty [Elektroda, tomiok, post #16594219]
• Brands offering 3-year battery cover: DeWalt, Metabo, Sparky [Elektroda, E8600, post #16593858]
• Typical Li-ion rebuild cost: 50–70 % of new pack price [Elektroda, E8600, post #16597189]
Which cordless drill-driver gives the best torque under PLN 600?
Among mainstream brands, the Bosch GSB 180-LI leads with 54 Nm, edging Makita DF457DWE’s 42 Nm and most supermarket models’ 45 Nm [Bosch Spec Sheet; Makita Catalog; Elektrode, tomiok, #16594219].
Does the Bosch blue (Professional) line really last longer than green?
Yes. Blue models use metal gears and higher-grade cells; users report years of service, while green versions “break down quickly” [Elektroda, tomiok, post #16593994]
How long will the supplied 1.3–1.5 Ah batteries survive?
Li-ion packs handle about 500 full cycles before losing 20 % capacity [BatteryUniversity, 2023]. With hobby use, that equals roughly 5–6 years, provided you avoid deep discharges [Elektroda, Tommy82, post #16596413]
Can I rebuild a dead battery pack myself?
Yes. Replacing 18650 cells restores life at 50–70 % of new-pack cost, but you need spot-welding equipment and the correct BMS board [Elektroda, E8600, post #16597189]
Is the hammer (impact) function useful for DIY woodwork?
Not really. Hammering helps in masonry; it adds weight and more moving parts without benefit in wood [Elektroda, leotdipl, post #16597397]
Are supermarket drills from Lidl or Biedronka worth considering?
For occasional use, yes. Parkside 20 V kits cost PLN 299, include 3-year warranties, and perform “fine for smaller tasks” [Elektroda, tomiok, #16594219; Zbigniew 400, #16593901].
Which brands give 3-year battery warranties?
DeWalt, Metabo and Sparky currently register packs for 3 years, covering early cell failure [Elektroda, E8600, post #16593858]
How can I extend battery life?
  1. Stop drilling at the first slow-down.
  2. Recharge to 80–90 %, not 100 %, for storage.
  3. Store packs at 10–25 °C and 40 % charge state.
    These steps double cycle life in lab tests [BatteryUniversity, 2023].
Is a corded drill a better choice for rare use?
Possibly. Owners who used cordless rarely found batteries dead after two years and switched to 230 V models to avoid replacements [Elektroda, ^ToM^, #16597936; LightOfWinter, #16598109].
Can I use normal bits in an impact drill?
Yes for light jobs, but impact-rated bits resist shank twist when hammer mode is active, reducing breakage risk [DeWalt FAQ].
What edge cases should I watch for?
Low-cost tools may list 2 Ah packs yet hide 1.3 Ah cells inside; always weigh the pack and verify capacity before purchase [Elektroda, E8600, post #16597189]
