Media-tech MT-3325 Speakers: No Sound on Computer, Working on Cell Phone, Sound Card & HP Drivers
PolskiWariat 9954 7
  • #1 16600005
    PolskiWariat
    Rate: 18
    (I don't know if it's a good department, if it's bad, please move)
    Hello, speakers came to me today, Companies: Media-tech [MT-3325]
    when connected to a computer they do not work, but when I connect to a cell they emit sound in the sense of firing mp3, i.e. the speakers are functional.
    I have RAZERA headphones (USB input) and they work when I connect them. I don't know if I have a sound card I know it's stupid but (dxdiag) says: No sound card found. To find it, install the sound driver provided by the hardware manufacturer. When I go to the Hp website where the drivers are located, etc. I download everything from the sound department, but when installing later, I write that this driver does not match this device (although the speakers are not connected)
    The 3.5mm Mini Jack inputs do not work even when connecting some cellular headphones (I checked from the front and back). It is worth adding that when I had a computer (new) it had a loudspeaker inside the computer and was connected to an additional port where it writes "SPEAKER" of course it upset me and I dismantled it. Do you think it's a sound card and you need a new one? Good end of this gibberish, if something is unclear, write I will give the parameters:
    Motherboard: 437795-001 437354-001
    350W Hp power supply
    mariuszp19
    Help: 310
    Rate: 409
    The sound card is integrated on the disc. Probably the fault of the drivers. Paste the device manager view. What system?
  • #3 16600107
    PolskiWariat
    Rate: 18
    Windows 7 64 Bit
    I had drivers from "nVidia" but uninstalled because they did not work
  • #5 16600158
    PolskiWariat
    Rate: 18
    mariuszp19 wrote:
    After all, in this thread https://www.elektroda.pl/rtvforum/topic3305501-30.html you wrote that the problem was solved.
    Yes, it was ok then, but now as you can see they do not work there in the volume control option I could select the speaker (SRS premium sound) now I can only select the digital audio device (HDMI) but can download this nvidia driver and try it with it? Because when I download the driver from the hp website, I get a notification "Audio Driver Files Do Not Support This Computer's Equipment"
    mariuszp19
    Help: 310
    Rate: 409
    Install Realtec AC'97 Audio Codecs drivers.
  • #7 16600249
    PolskiWariat
    Rate: 18
    I get a problem that I don't have the rtkvac64.sys file in the x64 folder but I don't know where I have this folder because I downloaded the file from the internet. i only have windows x32 but x64 not but pasted there and nothing
    Added after 1 [hours]:
    After the installation, I reset the computer, but none of this goes "X" on the speaker
    I'll see how it looks with "nvidia" drivers
    Added after 58 [minutes]:
    Now there is nvidia output instead of digital audio device (HDMI) still not working, I will see what windows update will download
    Added after 38 [minutes]:
    I installed and it doesn't work
  • #8 16605059
    PolskiWariat
    Rate: 18
    SRS Drivers Control panel installation reset later bios and change to everything related to sound @ mariuszp19 you helped thanks man :P :D :) ;)
The user reports that their Media-tech MT-3325 speakers function correctly when connected to a cell phone but produce no sound when connected to a computer. The user is uncertain about the presence of a sound card, as a diagnostic tool indicates none is found. Attempts to install drivers from the HP website have failed, citing incompatibility. The user has also tried connecting headphones, which work, and has previously uninstalled NVIDIA drivers that did not resolve the issue. Suggestions from other users include checking the device manager for sound card status, installing Realtek AC'97 Audio Codecs drivers, and resetting BIOS settings related to sound. Despite these efforts, the speakers remain non-functional on the computer.
