[Solved] Accessing Shared Folders on Windows 7 via Kodi TV Application: Password Issue
m4xon 7407 3
  • #1 16612960
    m4xon
    Rate: 74
    I need help with computer and TV setup. Namely, I would like to be able to play computer data, photos, videos etc. on the TV. For this purpose, I installed Kodi TV applications. I checked sharing the folder on the computer (Windows 7) and found it through Kodi, but I can't enter because I have the message that I need a password, but I don't have any password set on the computer. I've never shared anything on a local network before, so maybe I'm doing something wrong. I would be grateful if someone could tell you step by step what to do.
    Thanks in advance
    max
  • #3 16627402
    m4xon
    Rate: 74
    I managed to get through using Kodi and sharing. Thanks so much for your help
  • #4 17541594
    m4xon
    Rate: 74
    Thank you for your help
