Choosing the Right PP Pipes for Small Bathroom Renovation with 60-liter Boiler
michalbaran12 4017 5
  • #1 16618778
    michalbaran12
    Rate: 11
    I started the renovation of the bathroom and I have this question because I do not know how to choose pp pipes. I have 3/4 steel supply. In the bathroom there will be a shower, sink, toilet, washing machine and a 60-liter bolier.
    I was thinking about pulling everything cold 25 pp and from pain 20.
    will I do it right?
    and I have a question, is there any special pp to choose?
  • #2 16619461
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    It is unlikely that you should use plastic pipes for the boiler, as the water temperature in the boiler sometimes reaches 80 degrees. There must be a special material (for hot water) to make it copper or steel.
  • #3 16619521
    michalbaran12
    Rate: 11
    I was wondering about the warmth of the water strengthened. But I do not know why my bolier heats the water to 60 degrees has the greatest eegulation. this is an electrical bolier
  • #4 16619767
    stanislaw1954
    Help: 2013
    Rate: 4675
    Have you heard about stabilized pp pipes? High temperatures are also encountered in CO.
  • #5 16619834
    michalbaran12
    Rate: 11
    I have heard and read that they can withstand the heat of water. but I mainly mean what sections should be given so that it has arms and legs. How or cold, because I have a power supply of 3/4 and probably it is best that the main one is of a similar diameter and then the branches are smaller but I do not know what diameter. and what to give from bolier?
    stanislaw1954
    Help: 2013
    Rate: 4675
    The boiler has 1/2 "connections, so it will not be possible to distribute hot water pipes with a thicker cross-section. Give 20. And a cold in such a bathroom is also enough 20. After all, you use one shot at a time. there is nothing to mention.
