Iveco Daily 2007 2.3 35c12: Fuel Level Indicator Failure Despite Functional Float and Fuses
matiNowy52 14295 1
  • #1 16619122
    matiNowy52
    Hello, the fuel level indicator does not work. The float is working, the connection cube next to the radiator is also OK, the fuses are also all right. What may be the reason for the lack of indications? Thanks in advance for any helpful tips
  • #2 16620381
    sulof1601
    Help: 94
    Rate: 281
    Hello. Check the cubes under the counter, it would also be nice to test the computer indicators to rule out errors on the counter plate.
