Berlingo 2009: Faulty Window Control, Broken Wire & Ineffective Telecoding - Seeking Suggestions
autoas 20754 13
How do I diagnose and fix a 2009 Berlingo front window that only goes down or no longer responds after a broken wire in the door harness?
The most likely fault is a broken wire in the door-to-body harness, especially in the rubber boot; one case was traced to a thin blue wire from the window motor, and another to a broken green wire, both fixed by unplugging the harness and repairing the wire [#18883102] [#20028157] Check the switch panel and the BSI with a meter, because the window switches use resistor-based signaling and the control may be handled by the BSI [#16621701] [#16622572] If the switch contacts are dirty or damaged, clean the switch board thoroughly with acetone or nitro and test again [#16621392] If the window still does not respond, try resetting by disconnecting the battery or the door controller for a while [#16621392] Telecoding alone is unlikely to help if the wiring or switch signal is faulty [#16621701] [#16622572]
  • #1 16621156
    autoas
    Help: 571
    Rate: 3924
    Hello!
    The fault started so that, regardless of whether it opened or closed with the button (window control when running) the window was going down .....
    Now the left window driver does not react (I found one broken wire and I did not change anything), the right one goes down no matter what the position of the switch ... after connecting the left motor to the right the same reaction ...
    In the planet, it is not possible to control the windshields (there is no such choice ...) can only control the rear windows that are not?
    I've done telecoding and nothing helps!
    Maybe some suggestions ....
    Pfemek
    Help: 83
    Rate: 342
    Window switch on "elastics"? If so, check the switch board for damage. Wash thoroughly with acetone / nitro, indifferently and check the reaction. And if the glass does not work at all, then do a reset, unplug the battery or the door controller for a while ...
  • #3 16621500
    autoas
    Help: 571
    Rate: 3924
    Well, unfortunately I did it .... clean erasers even skipped them and then lime ...
    g107r
    Help: 811
    Rate: 993
    I don't know if it will be useful, because another car, and I would probably not know how to check the control of these relays / module - probably already from the buttons :) , but that I saw there 2 post, it is https://www.elektroda.pl/rtvforum/topic1283523.html
  • #5 16621566
    autoas
    Help: 571
    Rate: 3924
    This is a completely different matter ...
    kortyleski
    Help: 957
    Rate: 3860
    As befits a Frenchman, it is probably resistance control and BSI rules. I may be wrong but probably not. If I'm not mistaken, measure the switches as they state. Tester doesn't show commands?
    seat21
    Help: 151
    Rate: 399
    maybe the water got on the plate bsi I had such cribs in 307
  • #8 16622171
    autoas
    Help: 571
    Rate: 3924
    I can't understand that I don't have windshields at Lexi ????
    In tests and in the preview there are only the rear ones, which are physically missing ....?!
    I did the coding for "panel van" and "sedan" were the only possibilities and it didn't work ...
    The customer has it from the news and it used to be good ....
    kortyleski
    Help: 957
    Rate: 3860
    Meter and see what happens at switches and at BSI itself. switches have resistors inside?
  • #10 18714536
    dycha86
    Some time has passed since the last entry ... my Berlingo has the same glitch and I wanted to know if the problem was resolved?
    sirsizar
    Help: 27
    Rate: 42
    Peugeot Partner 2011 1.6 HDi .. Problem with the left window
    When pressing the window button up, the glass went up, when pressed down, the glass went up !!!
    Cause: frayed wiring harness between the door and body (broken thin blue cable from the window motor)
    You have to remove the door to fix it and get a new set of clips for the plastic door side, because almost all of them are broken.
    best regards
  • Broken green wire in door harness fixed window control
    #12 20028157
    czerwan1
    Citroen Berlingo III 2013 1.6 HDi .. Problem with the left window.
    For me, the glass only worked downwards. After opening, each movement of the window switch caused the window to go down.
    6-wire elevator motor. Broken green wire from the bundle.
    Remove the rubber from the bundle between the bodywork and the door. Unplug the harness plug and repair the broken wire.
    It is not necessary to remove the door.
    A colleague led me.
  • Possible relay location and motor pin voltage diagnosis
    #13 20306534
    burny123
    I had the same fault in Berlingo Van 2015, the green wire was also broken.
    I fixed and checked and now the connections from the main cube of this harness to the engine cube are working.
    Unfortunately, manipulating the button does not cause the window motor to work.
    Before I started the repair, I heard a relay clicking on the left side. When I tried to "track" it by operating the button, after some time it stopped responding.
    Where can this relay be placed? in the engine?
    I also measured the voltages on the motor cube. I have mass and constantly fed 12 V on the middle pins. On pins 1 and 6, whether I press the up or down button, 12 V is fed to both pins at the same time.
    Is there any other control module somewhere?
  • #14 20814416
    wojtekkrski
    Hello, does anyone know what was the cause of the left window not working? I have the same problem as the colleague above
The discussion revolves around a 2009 Citroen Berlingo experiencing issues with window controls, specifically a malfunction where the left window does not respond and the right window descends regardless of switch position. Users suggest checking the window switch for damage, inspecting the wiring harness for frayed or broken wires, and ensuring proper telecoding. Some users report similar issues in other models, indicating that broken wires in the door harness are a common cause. Recommendations include measuring switch resistance, checking the BSI (Built-in Systems Interface), and ensuring that the control module is functioning correctly.
