Orange PI PC Domoticz - no GPIO pins in the list after export in Armbian
wampirek 2049 0
  • #1 16641144
    wampirek
    Help: 17
    Rate: 12
    I have a small problem with wiringPI, namely:
    Armbian system
    orange PI PC
    symptoms
    I'm using orange for domoticz everything works as expected no crashes no problems however when I export pins 68, 71, 199, 198, 200, 201 they do not appear in the list of exported gpio despite restarting domoticz
    I do the export with the command
    "gpio export 200 in"
    These are the numbers obviously given from the BCM table presented thanks to the command
    "gpio readall"
    In addition, if I call the command "gpio exports" despite exporting the aforementioned pins they are not in the list
    The funny thing is that I can control these pins with the gpio command without any problems. Anyone have any ideas???
    Aaaaa I forgot to add that I've already checked my google knowledge hundreds of times
    For the moderator:
    If my post is in the wrong category please move it to the correct one.
