#1 16653878 21 Aug 2017 08:30 campeon48 campeon48 Level 7 Posts: 17 Rate: 5 » | Topic author Post #1 16653878 21 Aug 2017 08:30 As soon as I connect the phone to the charger, I immediately lose range. What is going on? I will note that this is not the fault of the charger.
#2 16659106 23 Aug 2017 17:54 AmebaxD AmebaxD Level 9 Posts: 12 Rate: 14 » | Helpful post? (+2) Post #2 16659106 23 Aug 2017 17:54 There may be a short circuit in the charging socket. I would advise you to check if it is loose - such an injury can lead to the phone breaking. In my Lumia 535, after connecting a functional charger, the microphone stopped working for this reason.
#3 17386019 15 Aug 2018 17:16 Anielka12345 Anielka12345 Level 7 Posts: 5 Rate: 3 » | Helpful post? (0) Post #3 17386019 15 Aug 2018 17:16 Same for me. I am charging the lenovo c2power and I have no range while charging. The phone is new.
#4 17386248 15 Aug 2018 19:57 nutergsm nutergsm VIP Meritorious for electroda.pl Posts: 8429 Help: 1034 Rate: 1666 » | Helpful post? (0) Post #4 17386248 15 Aug 2018 19:57 As it is new, it is recommended to return it for a warranty repair.
#5 17386706 16 Aug 2018 02:23 oMATRIXo oMATRIXo Level 11 Posts: 21 Help: 3 Rate: 1 » | Helpful post? (0) Post #5 17386706 16 Aug 2018 02:23 Try to charge it by connecting to the computer, if the problem disappears, change the charger.
