digital polsat / 90 antenna - weak signal from the antenna 66%
BATMANZKS 9939 10
Why does my satellite antenna signal stay at 66% even after replacing the dish with a 90 cm one, and how can I improve it?
The signal stays at 66% because the dish is not being aligned correctly, so a larger antenna alone will not raise the reading. Use the signal quality, not just the strength bar, and align the dish with a meter if possible because setting it by the decoder alone is unreliable [#16656653][#16659900] The LNB/converter also needs to be rotated slightly; in this case it should be almost vertical and then turned gently to the left, about 6° from vertical [#16659900] Check that the LNB arm is not bent and that nothing blocks the dish, and verify the coax cable quality and length [#16656546][#16656963] If you move the dish, make very small adjustments and wait for the decoder display to refresh [#16657584]
  • #1 16656521
    BATMANZKS
    Why can't I set a higher antenna signal than 66%. I bought antenna 90 recently because it was 60. I was hoping that it would improve signal strength but none of these things signal strength is the same. Why ??
    The antenna is set up like this .. digital polsat / 90 antenna - weak signal from the antenna 66% digital polsat / 90 antenna - weak signal from the antenna 66% digital polsat / 90 antenna - weak signal from the antenna 66%
  • #2 16656546
    mariuszp19
    Help: 310
    Rate: 409
    What did you set the antenna for? The converter should also be twisted. What cable length and quality?
  • #3 16656559
    BATMANZKS
    I set the antenna manually looking at the signal strength. The most ordinary coaxial cable. Converter turn ?? But how ? Cable length to one TV eye 10 m decoder with digital polsat, to another about 30m strength 100% somehow 27% NC decoder +
  • #5 16656653
  • #6 16656963
    LeDy
    Help: 1992
    Rate: 2940
    There are no obstacles in front of the canopy, nothing covers?
    The decoder and its indications are sufficient for setting.
  • #7 16657292
    simhak
    Help: 109
    Rate: 336
    The converter boom arm is not deformed?
    Rotate the converter a few degrees in the handle.
  • #8 16657584
    klopsik_wieprzowy
    Note that the decoder may display a delayed change in signal strength. Therefore, by positioning the antenna we make a minimal movement of the dish and wait a moment to refresh the value on the screen.
  • #9 16659635
  • #10 16659697
    andpol 33
    Help: 513
    Rate: 1146
    So what's the decoder? First you write about low strength, then about quality. So how?
  • Adjust the converter about 6° left from vertical
    #11 16659900
    _kli_
    Help: 762
    Rate: 1040
    This Corab model has it.
    Quality is more important.
    The second photo shows that the converter is almost vertical. Standing in front of the antenna, you turn it gently to the left. At your location, it should be approximately 6 ° from the vertical.
The discussion revolves around a user experiencing a persistent weak signal of 66% from a newly purchased 90 cm antenna, despite expectations for improved performance over a previous 60 cm antenna. Various responses suggest checking the antenna's alignment, the quality and length of the coaxial cable, and the positioning of the converter. Recommendations include using a signal meter for precise adjustments, ensuring no obstructions are present, and making slight adjustments to the converter's angle. The importance of signal quality over strength is emphasized, along with the potential for delayed signal readings on the decoder.
