Satel Perfecta 16 WRL Control Panel Connection Issue: Computer Not Detecting, Keypad No Connection
kamykmg 15930 6
  • #1 16661829
    kamykmg
    I have a problem connecting the Perfecta 16 WRL control panel to the computer. The USB RS driver and Perfecta Soft program have been installed on the computer. Despite this, the computer still does not detect the control panel and you cannot connect to it to add the keypad. The keypad, on the other hand, displays "No Connetion (CLK / DATA)." I attach a picture of the control panel connection, because maybe something is wrong with the cables.
    Satel Perfecta 16 WRL Control Panel Connection Issue: Computer Not Detecting, Keypad No Connection Satel Perfecta 16 WRL Control Panel Connection Issue: Computer Not Detecting, Keypad No Connection Satel Perfecta 16 WRL Control Panel Connection Issue: Computer Not Detecting, Keypad No Connection
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues A collection of topics
    Outputs (programmable and not only) for control panels
    How the control panel alarm outputs work
    Connecting any detector to any control panel - guide
    How to connect the siren to the control panel - guide
    We invite you to familiarize yourself with other guides, featured topics, articles on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides on security systems
    If the above topics do not find the answer to your question, please visit the forum:
    Security Systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those starting their adventure with electronics:
    General Guides
  • #2 16661889
    bhtom
    Help: 444
    Rate: 601
    What do you think is supposed to result from the pictures posted? After all, it is a "naked" CD to which aku and AC from trafa are connected. And, of course, the programming cable ...
    Greetings.
  • #3 16661892
    kamykmg
    Greetings.
    It's bare because it's a wireless alarm system.
    The keypad and motion detectors are wireless, which are added to the control panel by means of the Perfecta soft program. Unfortunately, the computer does not connect to the control panel ...
  • #4 16661939
    reweriko
    Help: 65
    Rate: 99
    6.5.1 Connecting the keypads ........... the instruction bows .....
    ALLSYSTEM
    Krzyżowa, Bytom, 41-909 | Tel.: 530XXXXXX (Show) | Company Website: http://allsystem.eu
  • #5 16663687
    kamykmg
    Next, the computer does not connect to the control panel ...
  • #6 16663958
    suworow
    Help: 650
    Rate: 1276
    In the light of the information provided, I can only say that a colleague must try further.
    ps. It just so happens that I have a similar center on the wallpaper (perfecta 16). This is my second meeting with this equipment.
    Maybe this description will help somehow. I specifically started the control panel without a keyboard ;)
    1. I unpacked and threw away any unnecessary garbage including programming instructions.
    2. I installed trafo, control panel, antenna, etc.
    3. I connected the cable (pin 3 - RS) to the appropriate connector of the control panel and then connected to the computer through a USB-RS adapter.
    4. I fired Perfecta soft and connected the power supply. The plate did not get up.
    5. I was about to put a subject on the electrode, but I just remembered that I did not put a fuse ....
    6. Next, no connection. Write not write, but what will I be hard and try to manage myself. I checked the port. It turned out that my adapter is not detected. Well, I did not use this adapter.
    7. After changing the adapter I got a connection. :D
    Duration of the operation, including a cigarette break, approximately 20 minutes.
    ps2 I say yes, or he will start to treat us seriously and describe the program settings carefully, the cable used, step by step performed activities, or the subject flies to the trash. I am sorry but I can not help someone who can only write that it does not work.
    Even such a punk of regulations speaks about it:
    3.1.15. Do not ask at once on the forum, if you have not checked anything before or did not attempt to diagnose yourself. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should contain the brand, model and brief description of the fault.
  • #7 16671625
    kamykmg
    It works! It was enough to change the port in perfecta soft. Thanks
✨ The discussion revolves around a connection issue with the Satel Perfecta 16 WRL control panel, where the user is unable to connect the panel to a computer despite having installed the necessary USB RS driver and Perfecta Soft program. The keypad displays a "No Connection (CLK / DATA)" error. Responses suggest checking the wiring and connections, as well as ensuring the correct port is selected in the Perfecta Soft program. A user eventually resolves the issue by changing the port settings in the software, allowing successful communication with the control panel.
