[Solved] Satel Perfecta 16 WRL Alarm Control Panel: Troubleshooting RS232 Cable Connection with Dell Laptop
markode 6684 4
  • #1 16845067
    markode
    Rate: 140
    I have a question about the Satel Perfecta16 WRL alarm control panel, the problem is with the communication with the computer, I use an RS232 cable identical to the Satel Micra programming, with which I have never had a problem with the communication with the computer, when I bought the seller informed me that I would connect with the same cable as for the Micra module but unfortunately I have no connection, of course I checked all the setting options from COM1 to COM4 but there is no connection, I will add that I use a Dell laptop with RS232 socket for programming
  • #2 16845304
    skyguy
    Help: 19
    Rate: 185
    Do you have the control panel key the same as the one entered in Perfecta Soft?
  • #3 16858482
    iDest
    Pupil
    Rate: 11
    Check the COM port in device manager and then communication keys
  • #4 16860219
    michualex
    Help: 82
    Rate: 134
    did you tighten the rj plugs in the barrel? I freak out sometimes.
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #5 17108797
    markode
    Rate: 140
    The problem turned out to be a damaged rs232 cable
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues Collection of topics
    Outputs (programmable and not only) of control panels
    How the control panel alarm outputs work
    Connecting any detector to any alarm control panel - guide
    How to connect the siren to the alarm control panel - guide
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If the above-mentioned topics do not find an answer to your question, please visit the forum
    Security systems
    We encourage youalso to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
