Displaying the Control Panel Key on Satel Perfecta 16 WRL for Remote Login via Perfecta Soft
mdi87 20664 6
  • Need for control panel key to log in remotely
    #1 18392082
    mdi87
    Hello, is it possible to display the control panel key on the keypad or in some other way, I have a fully working alarm, the control panel key I need to log in remotely via perfecta soft, I have ID and IMEI.
    Announcement
    We invite you to familiarize yourself with guides, highlighted topics, articles in the field of security systems such as intercoms, automatic gates and barriers, alarm systems, cameras, access control:
    Security systems guides
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those for people starting their adventure with electronics:
    General Guides
    adamjur1
    Help: 772
    Rate: 1003
    satellite
    LIST
    FUNCTION
    SERVICE
    2. Service mode menu
    End of TS
    0.System
    00.Server Password ..................................................... ..[12345]
    01.central key ..................................................... ............
    02
    Regards J
  • #3 18392123
    mdi87
    Can you explain it in more layman's terms? 😁
    adamjur1
    Help: 772
    Rate: 1003
    It can't be more. Manual Service Function List (from the satellite website) and you read it on the encryptor.
    Regards J
  • #5 18428977
    MateuszM12345
    Level 4  
    Rate: 8
    I don't know if the topic is closed, so I'll write:
    On the keypad, enter:
    1. service password and asterisk (default 12345)
    2. Start the service mode (in the menu, press the up arrow once and then the # key)
    3. Enter 01#
    4. The PBX Key needed to connect to the PERFECTA soft program is displayed
    Now to exit press 2 times asterisk and when the arrow shows End TS press #
    [/b]
  • #6 20036939
    Saxston
    I do point by point and I don't see the code.
    When I enter 01#, I immediately hear a sound and immediately log out of the admin level.
    Any other advice on this topic?
The discussion revolves around displaying the control panel key on the Satel Perfecta 16 WRL keypad for remote login via Perfecta Soft. Users are guided to enter the service password (default 12345) and navigate to the service mode to access the PBX Key. However, some users report issues with logging out immediately after attempting to display the key, prompting suggestions to identify the keypads used. The responses emphasize following the service function list and using the correct sequence to retrieve the necessary information.
