Electrolux EDP12074PDW Dryer - Persistent EHO Error, Ticking Sound & Incomplete Drying
becia00000 22485 4
  • #1 16676582
    becia00000
    Hello, I have a problem with the dryer, after turning it on for a while, then the display shows the EHO error and a sound signal. Previously, it appeared sporadically, now almost always and is unable to complete drying. There is a ticking sound in the programmer before the error is displayed. No explanation in the error designation instructions. I am asking for help or suggestion what to do about it.
  • #2 16677361
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3826
    becia00000 wrote:
    after switching on, it works for a while and then the EH0 error appears on the display
    Check the power supply (network voltage too low). Remove any extension cables and an error will occur after grounding properly EH0 should disappear. If it is still the same then the module should be repaired at the electronics :D
  • #3 16678701
    becia00000
    I connected directly to the socket, still the same, also the second option. Thank you for the advice, best regards.
  • #4 16679854
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3362
    TONI_2003 wrote:
    it is rather a module for electronics repair :D
    This module unsuitable , from this series of dryers, for repairs, even by very capable electronics.
    Not this class
    Have you ever taken apart such a machine?
    If not, don't bother.
  • #5 16841900
    becia00000
    The repair lord said the same as suggested in the forum, the dryer was also scrapped. Expected repair price about PLN 600. and I bought a new one.
