Electrolux EDH13386GW Dryer's Incomplete Drying Issue After Three Years of Use
Radziu3003 14217 3
  • #1 16797116
    Radziu3003
    After three years of use, it has stopped drying from new, after almost two hours of grinding no matter what program the laundry is still very moist on. The dryer behaves the same; turns, heats up, etc. Sometimes, however, the program ends prematurely, although it happened before. After another drying cycle, it ends faster again, but the laundry is still damp.
    The first thing that comes to mind is the humidity sensor, but I can't locate it, photos below. The second is maybe a clogged condenser / heater (I don't know what it's called exactly, but it looks a bit like a radiator in a car), it is right behind the filters, which are cleaned each time, so maybe there is no power? The air intake filter is rather absent, at least not located.
    inquire :)
    Electrolux EDH13386GW Dryer's Incomplete Drying Issue After Three Years of Use Electrolux EDH13386GW Dryer's Incomplete Drying Issue After Three Years of Use Electrolux EDH13386GW Dryer's Incomplete Drying Issue After Three Years of Use
  • #2 16798245
    MARCIN.SLASK
    Home appliances specialist
    Help: 1036
    Rate: 2650
    You need to disassemble and clean the fins, all ducts, turbines well, so that the air passage is not blocked. There may also be a gas system leak and thus low efficiency, not sufficient for drying.
  • #3 16798265
    widaw
    Help: 21
    Rate: 173
    I understand that the compressor is working? If so, clean the entire system.
  • #4 16972748
    Radziu3003
    I called for service - they stuffed the tubing underneath with a syringe of water. Together with the water they pumped up full of shit. Works better, but not like new :(
