Mercedes Vito 2.3D Engine Spins But Doesn't Start Despite Replacing Fuel Filter
psotnik12 8169 5
  • #1 16676841
    psotnik12
    Rate: 10
    Mercedes Vito suddenly died, I came with it without any problems, after 10 minutes I wanted to start it and unfortunately it did not speak.
    I have replaced the fuel filter, there is no air in the hoses, after loosening the injector nuts, pus slightly appears. Immobilizer removed someone once, I do not know where to look for the problem, anyone has an idea?
  • #2 16677108
    Pawel wawa
    Help: 1262
    Rate: 4433
    Does he smoke on the cake? This engine, when it has air and fuel, burns without any problem. Unless the pump is dead or the timing. The chain hasn't made any noise lately?
  • #3 16677116
    psotnik12
    Rate: 10
    It says on the cake, but it goes out after burning it, the feed pump gives fuel, but it goes to block it with your finger, I don't know if there should be more pressure ...
    There should be no valves on the injection pump to maintain the pre-pressure? Maybe someone has an injection pump diagram?
  • #4 18123798
    asrad
    Rate: 30
    Hello. I have the same problem with Vito 2.2 from 2017. What was with your car?
  • #5 18124258
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Don't be ridiculous - are you comparing the problem of an ordinary diesel from several years ago with a CDI engine from two years ago?
  • #6 21191037
    piesiakmarcin7
    Hey. Did you manage to solve the engine problem?
