Samsung Galaxy S6 - Fast loading does not work / the computer does not detect th
Reve47 7293 7
  • #1 16679130
    Reve47
    Hello. For several days I have a problem with my S6. Fast charging stops working and the computer does not detect the phone. After connecting it only loads it. I tried hard reset, I set the USB debugging and still nothing. I checked on another cable, on all inputs, etc. I would add that my other phone (also Samsung) is detectable both on the cable from S6 and from my powerbank. If it matters, my system is Win10.
    Please help. Greetings.
  • #2 16679157
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Press * # 0808 #, set AP and DM + MODEM + ADB, see if it will be visible through the computer
    Greetings
    GSM service
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • #3 16679164
    Reve47
    xbox-serwis.eu wrote:
    Press * # 0808 #, set AP and MTP + ADB, see if it will be visible through the computer
    Greetings
    GSM service
    I had everything exactly the same set up. The phone is still not visible.
  • #4 16679168
    xbox-serwis.eu
    Help: 52
    Rate: 210
    In that case, you have to break it down and put on a new connector, preferably with all flex :)
    XBOX-SERWIS.EU
  • #5 16679175
    Reve47
    There is no other solution? The cost of such unsticking is probably not so small.
  • #6 16679177
    xbox-serwis.eu
    Help: 52
    Rate: 210
    The cost of repair should not be higher than 150-200 PLN.
    Check again if the connector is sealed / corroded.
    Clean with a brush and some chemistry, e.g. IPA.
    Greetings
    GSM service
    XBOX-SERWIS.EU
  • #7 16679190
    Reve47
    I will try to clean and wait for the statements of others. Of course, if they appear. Thank you for your help :)
  • #8 16693839
    Reve47
    Hello. Today some update of the android appeared to me. After the update - the computer detects the phone. There is a quick charging issue that still does not work. Both on the original cable and the powerbank with fast charging function. Any ideas ?
The user is experiencing issues with their Samsung Galaxy S6, specifically that fast charging is not functioning and the device is not recognized by their computer, despite attempts to reset the phone and use different cables. Suggestions from other users include checking the phone's USB connector for corrosion and cleaning it, as well as considering a hardware repair if the problem persists. After a system update, the phone was detected by the computer, but fast charging issues remained unresolved.
