Iveco Daily 35c15 2006 Model: Seeking Electric Window Diagram with 6-Wire Motor Control
citromaniak 19026 7
  • #1 16686734
    citromaniak
    Help: 53
    Rate: 394
    Hello, I need the electric window diagram for this model. Good fuses, good lifters with motors, new, unbreakable cables in the door, checked with a multimeter, swap switches in working order. The problem is that I have a diagram for this Iveco, but there is a motor with 2 wires and I have 6 wires for each engine. Does anyone know how such a motor is controlled? Is there any window driver in this model? Year 2006.
    Added after 2 [hours] 25 [minutes]:
    citromaniak wrote:
    Hello, I need the electric window diagram for this model. Good fuses, good lifters with motors, new, unbreakable cables in the door, checked with a multimeter, swap switches in working order. The problem is that I have a diagram for this Iveco, but this is the engine with 2 wires and I have 6 wires for each engine. Does anyone know how such a motor is controlled? Is there any window driver in this model? Year 2006.
    There is one plus 12v on the cube for the window switch and it separates further on the window switch for the motor. On the switch correctly, i.e. once on one cable once on the other depending on whether we turn the top or bottom on the switch.
  • #2 17266242
    ITALMOTO
    Rate: 28
    Hello! and what iveco model did you have ?? older to 2006 or 2006 to 2012?
  • #3 17278449
    citromaniak
    Help: 53
    Rate: 394
    You know what about to close because the car is already repaired.
  • #4 17278551
    iDest
    Pupil
    Rate: 11
    What was?
    What was wrong?
  • #5 18061045
    Dżezer
    Buddy Citromaniak what was the cause of the fault because I have exactly the same problem as YOU ...?
  • #6 18061470
    citromaniak
    Help: 53
    Rate: 394
    Unfortunately, I don't remember anymore
  • #7 21188823
    mariusz18041988
    I have the same problem, tell me, how did you do it my friend?
  • #8 21188969
    citromaniak
    Help: 53
    Rate: 394
    In Iveco there are always cables in the doors, where the window motors are mini controllers which communicate via can with the body computer, otherwise the engine will not start.
The discussion revolves around the need for an electric window diagram for the 2006 Iveco Daily 35c15 model, specifically addressing a 6-wire motor control system. The user has confirmed that all components, including fuses, lifters, motors, and cables, are in good condition. However, they possess a diagram for a 2-wire motor, which does not match their setup. Responses indicate that the window motors in this model utilize mini controllers that communicate via CAN bus with the body computer, which is essential for operation. Several users express similar issues and seek clarification on the resolution of the problem.
