Seat Toledo II 2001: Can I Swap My Comfort Module (1C0 959 799 B) With a 1J0 959 799 AH?
gsebek9825 8952 3
  • #1 16692529
    gsebek9825
    Some time ago I tried to activate the closing of windows with a remote control in my toledo II from 2001. Unfortunately, the attempt to use a certain Czech program for this failed because my comfort module is probably incompatible with this program. The windows with the key close and open easily. At a friend's in the same session only from 2003. the program worked great. And here is my question: Can I exchange my comfort module (1C0 959 799 B) for one like my friend's (1J0 959 799 AH)?
  • #2 16693269
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    You can always do it is profitable?
    To complete the comfort you have to replace the drivers in the door because they do not get along.
    It must be the same type, i.e. the beginning of the assay must match - 1C0.
    Look for the VDC.exe program that works under DOS, for this VAG interface on RS232 and you will do the window closing.
  • #3 16693713
    gsebek9825
    Thank you very much for your answer.
    And you don't know where I can find instructions for such an operation? Is it also possible to set up folding mirrors from the remote control in this way?
