Best Semi-Professional Plasma Cutter: Tomahawk 1025 or Welder Fantasy CUT GALAXY 40A within Budget
Lolik112 4131 2
  • #1 16693815
    Lolik112
    I need to buy a plasma cutter for semi-professional use (I do not want to buy a cheap Chinese for PLN 1000 but I will not spend PLN 10,000 on a 1025 tomahawk either). My budget is from 3000 to 4000 PLN. One thing it must have is a pilot arc. The power supply can be 230 or 400V. It is mainly intended for cutting metal sheets up to 10mm thick, so I don't need big amps. There are many offers on the Allegro, but I can't decide, I hope that one of you will tell me what to buy.
    I found such a cutter on the Allegro:
    it has a quite interesting arc ignition system, I really like the fact that it has a display and a built-in reducer and a plasma cable for the euro connector, I just don't know if it has too low efficiency, only 30%.
    What do you think?
  • #2 16694047
    pawelradomsko
    Automation specialist
    Help: 111
    Rate: 109
    Hello!
    I was looking for a part-time cutter some time ago and found something like this:
    Sherman CUTTER 50K COMPRESSOR.
    Standard cutter for not very thick elements, but one thing convinced me - this built-in compressor - solved the problem of dragging additional weight when moving the equipment and it works without any problems. It seems pretty good for its price.
    Greetings.
  • #3 17483722
    potegat
    Rate: 109
    Gentlemen, let me reheat the cutlet
    I would like to buy plasma, I have two types
    IDEAL TECNOPLASMA 75 or Sherman CUTTER 70 similar parameters, similar prices. What do you think.
