Temperature Sensor CT4/CT4-P Repair & DIY Guide: KTY81/110, ecoMAX Controllers, and Accessories
grzegorzepj 12783 6
  • #1 16694932
    grzegorzepj
    If anyone was interested in repairing or making such a sensor, then I make the task easier because it took me a few hours to search the catalogs of the actuator that is in this sensor. KTY81 / 110 the sensor under the name CT4 is found in ecoMAX controllers and probably in many others
    auxiliary materials
    http://www.plum.pl/index.php/ekrany-graficzne/ecomax-850p-box#akcesoria
    https://elecena.pl/datasheet/136212/kty81-110/polprzewodnikowy-czujnik-1k-t-25-c-1-55-150-c
    Regards
  • #2 17076109
    palacz66
    Rate: 20
    And what is the resistor in the outside temperature sensor
    CT-4P? Maybe someone knows because after inserting the resistor PT 1000 shows 30C too much?
  • #3 17076241
    grzegorzepj
    I gave the ready answer, it is not a resistor, but a temperature sensor KTY81 / 110 search google I thought I described it clearly
  • #4 17400918
    giovaniiii
    For CO and DHW temperature sensors, the KTY81 / 110 sensor fits,
    whereas when connecting KTY81 / 110 as an external temperature sensor, the PLUM controller shows about 20st too little.
  • #5 19459918
    k_pawel
    CT2S-2 exhaust = pt1000
  • #7 20783542
    spformax
    It looks like the outdoor sensor and chimney sensor use the same sensor - PT106053 / SA10201521. I found 2 variants of this sensor.
The discussion centers around the repair and DIY aspects of the CT4/CT4-P temperature sensor, specifically focusing on the KTY81/110 sensor used in ecoMAX controllers. Users share insights on the compatibility of the KTY81/110 with various temperature sensors, noting issues such as incorrect temperature readings when connected to different controllers. The conversation highlights the use of PT1000 resistors and mentions other related sensors like CT2S-2 and CT6-P, indicating that some sensors may share components. Links to additional resources and datasheets are provided for further reference.
