Which temperature probes for the EVK 401 EVCO controller? Resistance 13.5 kΩ
bogdyk223 4425 1
  • #1 16455247
    bogdyk223
    Hi I have a few evk 401 evco controllers .They all work but I would like to buy a temperature court as a spare but I don't really know what type of court it is and the documentation doesn't have this information . I measured with an ohmmeter and the sensor is about 13.5 kilooms at 16-17 degrees celcius. Then I checked what thermistors in the documentation have a similar resistance but somehow nothing fits me.
    Maybe someone uses such regulators and can tell me what to buy thanks in advance
  • #2 16462774
    antek1cza
    Help: 182
    Rate: 199
    bogdyk223 wrote:
    Maybe someone is using such controllers and can tell me what to buy
    I do not use these controllers but it would be interesting to see their characteristics and choose the right one for your controller :
    Which temperature probes for the EVK 401 EVCO controller? Resistance 13.5 kΩ .
    The table is from http://ibros.pl/produal/-b-charakterystyki-b-czujnikow,163.html
    And you can find out about the sensors themselves e.g. by looking here http://ibros.pl/produal/pomiary-temperatury-c...k-ntc1800-ptc1000-0-10v-4-20ma-small-,49.html
    The different sensors can be seen e.g. here http://acse.pl/kategoria-produktu/czujniki-temperatury/
    ps.I am not related to any of the above companies, they just popped up the fastest when searching for information.
