Creating Plaster Dappled with Birch Broom: Ingredients, Proportions & Ready-Made Options
PchlaW81 25878 5
  • #1 16696115
    PchlaW81
    Help: 192
    Rate: 483
    Does anyone know of some ingredients such plaster is used to plaster houses, the birch broom was soaked, and the wall was dripped with it. I shoot it's cement, yellow sand and lime, but in what proportions? Alternatively, maybe someone met with something so "ready" because today such times that everything is available. Even the professional name of the plaster as if someone had given it, maybe I will get to the ball after the thread. I don't need much to process the door and garage door after insertion.
  • #2 16696246
    robokop
    Help: 1763
    Rate: 6376
    PchlaW81 wrote:
    Does anyone know of some ingredients such plaster is made that the houses were plastered in the past, a birch brush was soaked, and it mottled the wall
    This was how the so-called szpryc - a primer for proper limestone plaster.
  • #3 16696308
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    It all depends on what structure and color you want to get.
    Search under the name "lamb plaster" or "terabona plaster".
    The broom hit the slat made the structure. Probably in the 50s (although I do not know if not even before) special hand ejectors were invented:
    link
    As you can see, various modifications are available today.
    I used to plaster a house on the plot myself.
  • #4 16696414
    kortyleski
    Help: 957
    Rate: 3860
    This type of plaster was called territory I remember. It was based on white cement, pigments and probably something else.
  • #5 16696418
    PchlaW81
    Help: 192
    Rate: 483
    Thank you for the entries. Pl of these slogans I will find something .. Kisses
  • #6 16696469
    zimny8
    Help: 26
    Rate: 505
    And lime, in proportions adjusted by trial and error, differences resulted from the characteristics of the substrate and ingredients.
    Instead of pigments, plain gray cement was added to obtain shades of gray.
