Siemens iQ800 Washer-Dryer: Reviews, Drying Capacity & Power Consumption Discussion
Ludwik XVI 14997 13
Is the Siemens iQ800 WD15H542EU washer-dryer a good choice, especially for drying performance, load capacity, and power use?
The WD15H542EU can be a reasonable washer-dryer, but separate washer and dryer units are generally the better technical solution; if you still need a combo, this model was considered a fairly good choice with a detachable tank and relatively straightforward repair potential, though original parts are expensive [#16701350] One service technician reported a unit that died after 4 years, but also said the workmanship was good and the inside is complicated [#16696683] The owner who bought it said the hot-air drying system works surprisingly well without extra water consumption, but drying is limited to a maximum of 4 kg; with more laundry it does not dry properly [#16752765] He also noted that a 60-minute wash-and-dry program gives acceptable creasing, the machine is very heavy at 90 kg, runs quietly for its type, and throws warm air backward, heating the room [#16754250] A later report said the machine worked perfectly for almost 8 years with heavy use, then failed due to a burned heater, and still was recommended as a convenient combo for users who do not want to move laundry between two machines [#20645020]
  • #1 16696640
    Ludwik XVI
    Help: 1325
    Rate: 788
    Welcome,
    I have to replace my 12 year old washing machine, which is barely panting.
    I have a problem with drying clothes and that's why I'm looking for an integrated device.
    iQ800: http://www.siemens-home.bsh-group.com/pl/lista-produktow/pranie-i-suszenie/washing dryer/WD15H542EU?breadcrumb=washerdryers
    He has practically very good reviews.
    Defects found:
    - high power consumption - it doesn't matter to me because I have overproduction of energy by solar panels
    - a small amount of drying worries me a bit, but we'll get over it somehow
    Anyone know this model? There is practically no information on the forum ...
  • #2 16696683
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    I can comment on the part of the service technician. I have such equipment in the warehouse, unfortunately not functional, it died after 4 years. Complicated inside, but the quality of workmanship is good. Made in China.
  • #3 16696772
    Ludwik XVI
    Help: 1325
    Rate: 788
    Lodxx wrote:
    . Unfortunately, I have no such equipment in stock, it fell after 4 years. Complicated inside but the workmanship is good.
    Thanks for the opinion.
    I understand that it is not repairable?
    Lodxx
    Help: 105
    Rate: 245
    I do not know, for now I do not want to judge this equipment badly, it can be a case-by-case, but this is a bit of a test of quality, especially since Siemens has only been a brand for two years, Bosch's trademark, of course, is about household appliances. I would like something with a 5 year warranty.
  • #5 16697526
    Ludwik XVI
    Help: 1325
    Rate: 788
    It's hard to buy something sensible for these PLN 3,000.
    Like a lot of money but on Miele or AEG with a heat pump is not enough ;)
    In this Siemens (I also found the equivalent of Bosch) the plus is that it doesn't use water for drying. Interesting design ...
    Lodxx
    Help: 105
    Rate: 245
    Maybe something from candy, ariston? Look around for something that has a long warranty. Unfortunately, today's equipment for big money does not mean durability.
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Buddy, have you considered solving a separate washing machine and dryer?
    In my humble opinion, the solution is definitely better. It is no coincidence that the driers as separate devices have a different drum design, besides, the traditional dryer checks the humidity of the laundry, thus, it will finish the cycle when the clothes are dried. I don't associate washer-dryers with this feature.
    If there is a problem with the surface on which the devices are supposed to stand, it is possible to set them in a so-called post. Then such a bajer is used:
    http://www.bosch-home.pl/lista-produktow/pran...Z11400?breadcrumb=washersanddryersaccessories
    you screw it to the top of the washing machine and put a dryer on it. BSH had these connectors suited to the housings and it looks nice. All in a budget of about 3000, I think it will fit.
    If you allow two free standing devices, maybe Beko might be worth considering. Equipment like budget, but with a relatively simple design, and above all for relatively cheap original parts. Generally, this producer cannot be blamed for much.
    However, if for some reason it must necessarily be a washer-dryer, then the model you provided is a fairly good choice. The design is already a few years on the market, it changed a bit visually, that is control panels, door frames and so new models were created. An undeniable advantage is the detachable tank, which gives the chance to replace the drum bearings, which happened several times. The design seems to be complicated, in practice relatively pleasant even during severe demolitions. The only minus is quite expensive original parts.
  • #9 16701399
    Ludwik XVI
    Help: 1325
    Rate: 788
    I am still fighting for 2 devices, only then I have to remove a lot of shelves in the utility room.
    This is already a big block for me.
    Probably just let the wife decide and after the case ;)
  • #10 16706582
    mrice
    Help: 2213
    Rate: 6951
    I would recommend separate devices.
    I just sent friends today for this dryer:
    Bosch WTN86201PL
    A simple design, without fireworks and fountains, and more interestingly, cheaper than Beko.
  • Hot air drying works well up to 4 kg load
    #11 16752765
    Ludwik XVI
    Help: 1325
    Rate: 788
    Supplement.
    I bought WD15H542EU - washer dryer with an interesting hot air drying system without additional water consumption.
    This works surprisingly well, although you need to remember a maximum of 4kg loading when drying. As I loaded more, it failed to dry properly.
    The washing machine is heavy - 90 kg. Very stable.
    The operation is quiet for this type of drive. The quality of workmanship makes sense.
  • #12 16753898
    mrice
    Help: 2213
    Rate: 6951
    So, the combo won.
    Just because of curiosity, what about the crease during drying? Many of the clients I spoke to who had just had a washer dryer complained a lot about it.
  • #13 16754250
    Ludwik XVI
    Help: 1325
    Rate: 788
    Things are not perfectly simple but completely acceptable.
    Even in a short 60 min program (washing and drying) it is quite ok. Only then spin only 1500 rpm
    The dryer throws warm air backwards, so it additionally heats the room where it stands :)
  • Long-term reliability and convenience of combo washer-dryers
    #14 20645020
    celerrimus
    It is true that I came here on the occasion of the failure of this washer-dryer model, it seems that the heater burned out. However, up to that point, the washing machine worked perfectly, for almost 8 years of work with 2 small children. So often and with 3 washing and drying cycles per day. If anyone is thinking about iQ800 washer-dryers, I definitely recommend it.
    As for the previous discussion, there are indeed advantages to having a separate dryer. However, I think most users will find the combo device more convenient. The laundry is set to be washed and dry after these 3 hours - you don't have to watch it and move it between devices. If you remember after 8 hours, dry laundry will be fine too ;)
    Regards!
    p.
The discussion revolves around the Siemens iQ800 Washer-Dryer (model WD15H542EU) and its performance, particularly in drying capacity and power consumption. Users express mixed experiences, with some praising its efficient hot air drying system that does not require additional water, while others raise concerns about its drying capacity, noting a maximum load of 4 kg for effective drying. The unit's high power consumption is acknowledged, but some users are unconcerned due to solar energy production. There are mentions of alternative brands and models, such as Bosch and Miele, with suggestions for separate washing and drying units for better performance. Overall, the iQ800 is recommended for its convenience, despite some durability concerns and the potential for creasing in clothes during drying.
TL;DR: iQ800 drying works best at a max 4 kg load and owners say it "works surprisingly well." Real-world feedback highlights quiet, stable operation, with caveats on energy use. [Elektroda, Ludwik XVI, post #16752765]
Is the Siemens iQ800 washer-dryer good for daily family use?
Yes. One owner ran about three wash‑dry cycles per day for nearly eight years before a heater failed. They still "definitely recommend it" based on overall performance and convenience. This reflects heavy family usage with two small children. [Elektroda, celerrimus, post #20645020]
What is the real drying capacity I should plan for?
Plan for a maximum of 4 kg per drying cycle. Above that, clothes may not dry fully. Keeping to this limit delivers consistent results and prevents damp spots in thicker fabrics. [Elektroda, Ludwik XVI, post #16752765]
Does the iQ800 use additional water while drying?
No. This model uses a hot‑air drying system that does not consume additional water during the drying phase. Owners highlight this as a design advantage versus traditional condenser washer‑dryers. [Elektroda, Ludwik XVI, post #16752765]
How noisy or stable is it in practice?
Owners report quiet operation and very good stability. The appliance weighs about 90 kg, which helps reduce vibration during high‑speed spins and drying rotations. [Elektroda, Ludwik XVI, post #16752765]
How much energy does it use and who should care?
Users flag higher power consumption during drying. If you generate solar overproduction, the impact can be negligible. Without solar, expect noticeable energy use during long dry cycles. [Elektroda, Ludwik XVI, post #16696640]
Does drying increase creasing on clothes?
Creasing is present but acceptable, including on the 60‑minute wash‑and‑dry program. Using a 1500 rpm spin helps. If you need crisp results, remove items promptly or use an iron/steam finish. [Elektroda, Ludwik XVI, post #16754250]
Any reliability or repairability insights?
A technician notes the design looks complex but is pleasant to service. Another expert cites an "undeniable advantage"—a detachable tank that allows drum bearing replacement when needed. Parts can be pricey. [Elektroda, mrice, post #16701350]
Is a separate washer and dryer a better choice?
An expert recommends separate units for performance and moisture sensing. You can stack them using a dedicated connector to save space, gaining faster drying and better fabric care. [Elektroda, mrice, post #16701350]
Can I stack separate units if space is tight?
Yes. Use the manufacturer’s stacking kit to mount a dryer above the washer. It secures the units, saves floor space, and keeps access convenient. [Elektroda, mrice, post #16701350]
How do I improve drying results on the iQ800?
Try this: 1. Use the 60‑minute wash‑and‑dry program for small loads. 2. Set spin to 1500 rpm before drying. 3. Shake out garments before the dry cycle to reduce creasing and improve airflow. [Elektroda, Ludwik XVI, post #16754250]
Will the machine warm up the room during drying?
Yes. The dryer exhausts warm air to the rear, which can noticeably heat the utility room. This is normal behavior for its hot‑air system. [Elektroda, Ludwik XVI, post #16754250]
Where is the iQ800 made?
A service technician reports the unit as made in China, with good overall workmanship noted despite complexity. [Elektroda, Lodxx, post #16696683]
Any known failure modes to watch for?
One long‑term owner experienced a burned‑out heater after nearly eight years. Drying stopped, but the prior performance history was strong. "If anyone is thinking about iQ800, I definitely recommend it." [Elektroda, celerrimus, post #20645020]
What’s an early-life failure example?
A technician reported a nonfunctional unit after about four years. They described the interior as complicated yet well‑made, suggesting repairs might be nontrivial. [Elektroda, Lodxx, post #16696683]
Any budget-friendly alternatives mentioned?
An expert pointed to Beko as a cost‑effective brand with simple designs and affordable original parts. Consider it if you prefer separate units. [Elektroda, mrice, post #16701350]
Got a concrete dryer pick shared in the thread?
Yes. The Bosch WTN86201PL was recommended as a simple, good‑value vented/condenser option and reportedly cheaper than Beko at the time. [Elektroda, mrice, post #16706582]
