Dell Inspiron 90W Power Supply: 3-Pin Plug Voltage Issue, Should 5.5V Be 0V? Damage Risk?
vasil7 5178 5
  • #1 16701971
    vasil7
    The case concerns the Dell 90W power supply with a 3-pin plug.
    I already know that the mass is on the outside of the plug and the plus is inside, the problem is that I have a voltage of 5.5V on 3 pins, and it should be 0V !?
    Somewhere I read that there should be a resistance of 1.8 M between the third pin and ground, in my case it is infinity ...
    I would like to know if such a power supply is functional and if something can be damaged when there is voltage on pin 3
    Greetings.
  • #2 16701989
    xoree
    Level 30  
    Help: 129
    Rate: 174
    Take a photo (of this element) and show what exactly you measure (what and how).
  • #3 16702034
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Original power supply?
  • #4 16702037
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    There is a 1wire chip on the small pin in the dell for identifying the power supply.
  • #5 16702668
    vasil7
    the power supply is original dell
    the plug looks like this:
    there is a mass on the outer wall and a plus on the inside, in the middle of the plug there is a thin pin, i.e.
    I used this power supply in a car with an inverter, the inverter burned out, so I wanted to check with a digital meter if nothing happened to the power supply. Between the sides is normally 19.5V, and on the 3rd pin it is just like a colleague previously wrote the 1wire system to identify the power supply, but nowhere have I found a clear answer whether there should be voltage on the 3rd pin or 0V.
  • #6 18026275
    arturmarek1
    Rate: 15
    There should be 0V on the so-called pin.
