Shredding of TVN Channels on NC+ Platform: Antenna, TurboBox, Decoder & LTE Interference Issues
mkraska 18312 8
  • #1 16925141
    mkraska
    The aforementioned problem of "shredding" TVN channels on the nc + platform appeared on many forums, with no response.
    I also had this problem that I have been struggling with for several years.
    At that time, I replaced the antenna for a larger one, the TurboBox converter and decoder for another TurboBox.
    It did nothing, the signal level is 85% and the quality is 80%.
    Despite this, sometimes you can't watch channels from the TVN package (tvn hd, tvn turbo, tvn24, tvn style, etc.).
    I filed a complaint directly to nc +, but of course they don't see any problems.
    I recently noticed a strange relationship.
    If the room in which the decoder is equipped with a telephone with LTE (Orange) enabled, the TVN channel cannot be watched if the telephone is moved to another room, the reception is trouble-free.
    I have a question for people who know about wave interference.
    The nc + platform broadcasts TVN channels on a frequency of 11508V.
    On what frequency is it sent to the decoder?
    Is the LTE frequency any derivative of this frequency?
    How to protect yourself against the impact of LTE transmission on TVN channel reception on the nc + platform?
    Greeting
    Mariusz
  • #2 16925302
    maksar
    Help: 177
    Rate: 1029
    Read posts on this topic.
    Search option.
  • #3 16925318
    mkraska
    Search option.
    With all due respect, I haven't found the answer to the questions that bother me.
    Is the LTE (GSM) frequency any derivative of the transponder frequency from which the TVN nc + programs broadcast?
    How to protect yourself against the impact of LTE (GSM) transmission on TVN channel reception on the nc + platform?
  • #4 16925377
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Change the band on your mobile phone to 3G and put the LTE router (as you have it) as far as possible from the decoder. A car telephone or DECT telephone lying up to two meters from the decoder can interfere with reception of 11.508 and 12.476.
  • #5 16925412
    _kli_
    Help: 755
    Rate: 1031
    https://www.elektroda.pl/rtvforum/topic3136237.html#15272422
    https://www.satclub.pl/viewtopic.php?t=17425
    11508 MHz - 9750 MHz = 1758 MHz
    So if you have an LTE signal nearby 1800 , there is a likelihood of interference.
    Turn off or move the interference device away from the SAT installation, use cables with very good shielding, use a converter with LTE filter.
  • #6 16925427
    maksar
    Help: 177
    Rate: 1029
    The filter alone is not enough?
  • #7 16925457
    mkraska
    This is probably the case, only the LTE base station (Orange) transmits in the frequency range 1760.3 - 1769.9 MHz (uplink).
    So they shouldn't interfere.
    The problem would be with the Polkomtel (Plus) operator, whose frequency range (uplink) coincides with 1758MHz.
    I will remove all LTE transmitters from the salon and the problem (I hope) will disappear.
  • #8 16925958
    maksar
    Help: 177
    Rate: 1029
    Already scared that and BTSy.
  • #9 16939349
    KOCUREK1970
    Help: 3830
    Rate: 5422
    It can also interfere with radio internet and even a router in your own apartment.
✨ The discussion revolves around the issue of "shredding" TVN channels on the nc+ platform, where users report problems with reception despite having adequate signal levels (85% signal, 80% quality). The original poster has replaced their antenna and TurboBox decoder without resolving the issue. A potential cause identified is interference from LTE signals, particularly when a mobile phone is in proximity to the decoder. Users suggest switching the mobile phone to 3G, relocating LTE devices away from the decoder, and using well-shielded cables and converters with LTE filters to mitigate interference. The frequency of the TVN channels (11508 MHz) is noted to be close to the LTE frequency range (1760.3 - 1769.9 MHz), raising concerns about possible signal overlap and interference.
