Xbox One S tv and home theater - no sound on the console and video in 4k at the
lukaszek95 4215 6
  • #1 16712708
    lukaszek95
    I can't put the hdmi 5.1 sound on the console while having a 4k image. Namely, when I connect the Xbox to TV via HDMI, I have a 4k image but I can not set the 5.1 sound on the console. Of course, the sound comes out of the speakers from the cinema, but only in stereo, and when I connect the consoles to the cinema and only from the cinema to the TV, I can set the sound to 5.1 but then there is no picture in 4k.
    The equipment is Samsung ue48ju6000k tv and the home theater is Samsung ht-c5530
  • #2 16713456
    Polon_us
    Help: 1184
    Rate: 1282
    Please describe these connections used:
    - Xbox to TV HDMI, and the cinema?
    - Xbox to the cinema and then to TV - what connections?
  • #3 16748098
    awesela
    I have the same. What can be done, can something be done at all?
    Can Xbox one s support 4k and 5.1 audio simultaneously?
    Nobody gives such information, but the ads talk about "cheap home cinema", "two in one", etc.
    Can someone help?
  • #4 16876430
    lukaszek95
    Xbox to tv via hdmi and then there is 4k and cinema via optical to tv. I also have hdmi instead of optician. The second option is the console via HDMI to the cinema and from the cinema to the TV. In this setting, I have surround sound but I do not have 4k because the image from xboz still flies through the cinema
  • #5 16879766
    KOCUREK1970
    Help: 3867
    Rate: 5500
    lukaszek95 wrote:
    cinema by optical to tv.
    And why not the console directly under the cinema?
  • #6 16880164
    lukaszek95
    Well, then I do not have 4k on TV if I connect the hdmi directly from the console to the cinema: /
  • #7 16880246
    KOCUREK1970
    Help: 3867
    Rate: 5500
    A colleague did not understand what I quoted.
    From the console via HDMI cable straight to the TV
    Optical cable straight From the console to the CINEMA!
The discussion revolves around the issue of achieving both 4K video output and 5.1 surround sound from an Xbox One S when connected to a Samsung UE48JU6000K TV and a Samsung HT-C5530 home theater system. Users describe their connection setups, noting that when the Xbox is connected directly to the TV via HDMI, 4K video is available, but only stereo sound is output. Conversely, connecting the Xbox to the home theater system via HDMI allows for 5.1 surround sound, but sacrifices 4K video quality. Various connection configurations are explored, including using optical cables and direct HDMI connections, but no definitive solution is provided for simultaneous 4K and 5.1 audio output.
