[Solved] Long-term Usage Effects: Leaking Batteries in Samsung Remote Control Impacting Functionality
Dyncjusz 8820 3
  • #1 16716199
    Dyncjusz
    The batteries in the Samsung remote control leak after being used for a long time.
    External traces have been removed. The remote control has been dried, burned in, assembled and works. The problem is that after 20 minutes only 2 buttons work in it.
    What could be the problem and how can it be dealt with?
  • #2 16716247
    ADAM KAL
    Rate: 25
    Disassemble the remote control, when unfolding you need to be careful not to break the latches, wash the plate and rubber bands with extractive gasoline or salicylic alcohol and put it together and it should work.
  • #3 16716293
    szkieletor11111
    Help: 63
    Rate: 149
    Check all connections, especially those coming from the battery - plate or springs, and whether they have a good connection with the plate. Clean the gills properly.
  • #4 17104799
    Dyncjusz
    The problem could not be solved.
