Nivona 757 Espresso Machine Issue: Add Water Message Despite Full Tank - Seeking Solutions
rosos 14922 3
  • #1 16726143
    rosos
    Rate: 31
    I have a problem with the NIVONA 757 machine.
    After brewing coffee, the message top up water appears. Water was in the tank, removing and inserting the tank did not solve the problem. Exclusion also changed nothing.
    If anyone knows what to do, please let me know.
  • #2 16726922
    toolpusher
    Help: 35
    Rate: 210
    The floating magnet in the tank could get stuck. I don't know about Nivon but in Jura there is a magnet floating on the side of the bottom of the water tank. When the level drops, the magnet also activates the water level sensor.
    Or the sensor has gone down.
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3339
    Or a flow meter ...
    Often, leaks on the flow meter cause a similar symptom.
    Kawa i Naprawa - Serwis AGD
  • #4 16727611
    rosos
    Rate: 31
    Flooded flow meter.
