Solar Lamp with Motion Sensor (6 SMD LED) for Garage Lighting: Worth the Investment?
geforc 9771 9
Is a solar motion-sensor lamp with 6 SMD LEDs worth buying for basic garage entrance lighting when there is no electricity in the garage?
It can work for basic entrance lighting, but the thread leans against cheap solar motion-sensor lamps unless you accept limited durability. One user reports that a similar lamp in front of the garage has worked reliably, gives enough light, and the sensor works well [#16727982] Winter reduces charging because of the shorter daylight, although the lamp still charges itself from solar power [#16728169][#16728366] The strongest warning says these lamps are often poor quality: water gets in, motion/twilight sensors fail, batteries lose capacity after winter, and many last only 1–2 seasons [#16732760] If mains power were available, a 230 V lamp would be better and cheaper over time [#16728473]
  • #1 16727880
    geforc
    Rate: 44
    Hello, gentlemen, I don't have electricity in the garage and I need some lighting at the entrance, I found something like that
    https://toya24.pl/product-pol-10009947-LAMPA-...NNA-SOLARNA-Z-CZUJNIKIEM-RUCHU-6-SMD-LED.html
    have you had contact with something like this? is it worth buying such an invention?
    I would like to add that I do not expect who knows what spotlights. I just want it to be clear at the entrance if someone passes by.
  • #2 16727982
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. I have something like this in front of the garage and so far it is lit without failure, the light is sufficient, the sensor works well.
  • #3 16728008
    geforc
    Rate: 44
    How about rain and cold? Does it interfere with operation?
  • #4 16728169
    Pedros050
    Help: 2471
    Rate: 3927
    In winter, the battery is only charged less frequently due to the shorter working day ;)
  • #5 16728343
    geforc
    Rate: 44
    Are you charging at home or is it charging itself when installed?
  • #6 16728366
    Pedros050
    Help: 2471
    Rate: 3927
    The solar solar itself charges.
  • #7 16728473
    Jan_Werbinski
    Help: 76
    Rate: 671
    Not worth it. It's better and cheaper to connect the lamp to 230V. The amount of energy its battery stores throughout its life costs less from the power plant than the cost of another battery.
  • #8 16728483
    Pedros050
    Help: 2471
    Rate: 3927
    "Gentlemen, in the garage, I have no electricity". The author of the topic wrote.
  • #9 16728568
    geforc
    Rate: 44
    PITERRR I know that solar, only you wrote that in winter the battery charges more often and I did not understand;]
  • Cheap solar LEDs fail from water ingress and battery wear
    #10 16732760
    jojoro
    Rate: 10
    I do not recommend this solution. All these solar powered LEDs are linden. Theoretically, the housing is splash-proof, but only in the photo it looks good. You can see immediately that the water will get there. Service life, depending on the execution, 1-2 seasons. I have already processed about 3 models at similar prices and everything got soaked in a while and stopped working properly. What did not get wet, it broke in another way (e.g. damage to motion / twilight detection, loss of battery capacity after winter, etc.).
    Maybe these leds in metal housings for a few hundred PLN are more durable.
The discussion revolves around the viability of a solar lamp with a motion sensor and 6 SMD LEDs for garage lighting, particularly in areas without electricity. Users shared mixed experiences; one user reported satisfactory performance with reliable lighting and sensor functionality, while another raised concerns about the lamp's effectiveness in cold and rainy conditions. A few participants noted that the solar panel charges itself, but winter may reduce charging frequency. However, skepticism was expressed regarding the durability of solar-powered LEDs, with one user recommending alternatives connected to 230V for better reliability and cost-effectiveness. Concerns about water resistance and overall lifespan of solar models were highlighted, suggesting that more robust options may be necessary for long-term use.
