Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6.
kriss1974 18036 10
How can I fix the Samsung Account login loop / “Session has expired” problem on a Galaxy S6 so I can use Samsung apps again?
The problem was ultimately solved by doing a factory reset; after deleting the Samsung account on the PC and then restoring the phone to factory settings, the Samsung account stopped causing issues [#16744237] If you cannot remove the account normally because the login page keeps coming back, you can also erase the phone remotely through Google’s device tools / Find My Phone, which removes accounts too, but all data on the phone will be deleted [#16737424]
  • #1 16734061
    kriss1974
    Rate: 79
    WITAM forumowiczów "elektroda.pl"
    Recently, I installed 7.0 on my Galaxy S6 a few times and once I made a mistake somewhere and then the touch worked the other way around but I quickly got rid of this problem with the combination on the dialer "* # 2663 # *"
    Apparently everything has returned to normal but recently I noticed that I have a problem with the Samsung account and the notification bar constantly receives the message "Samsung account, Session has expired" or how I enter the page with applications for Samsung I can not install anything because it is redirected to the page login to the Samsung Account and how to log in it at the bottom pops up but the information that I'm logged in but the page login is constantly coming back which makes it impossible to install any app from the Samsung store.
    Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6. Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6.
    Thank you in advance for all your help.
  • #2 16734501
    gradek83
    Help: 930
    Rate: 2103
    Log in via the browser to the account of samsung https://account.samsung.com/membership/index.do
    Every 6 months, Samsung recommends changing the password change it (refresh)
    and maybe then he'll get it.
    Instructions for changing the password
    If you change the password on your device, you will be automatically logged out of your account to protect your privacy.
    Before changing the password, keep in mind the following information.
    1. Before changing the password, disable the "Re-activation block" on your mobile device. Otherwise access to services may be limited.
    How to disable the re-lock. activation (may vary depending on the device)
    Settings> Lock screen and security> Find my phone> Reactivate lock
    2. Backups of messages, contacts and other data will no longer be executed. To resume backups, you must log in again to the Samsung account on your mobile device.
    How to log in
    Settings> Accounts> Add account> Samsung account
    3. If you are using the Samsung Smart Home solution, the connection between the application and electronic devices will be turned off.
    4. If you log details of biometric data of banking applications using the Samsung Pass service, you must log in again using the Samsung account.
    Or Enter your phone's SETTINGS in ACCOUNT in the SAMSUNG account in Phone profile enter the password for the Samsung account Security tab and Device information and there you will have a list of devices you logged on, you may have doubled account connections with Android earlier if not, possibly log out of devices and delete the associated account and log in again.
  • #3 16734669
    kriss1974
    Rate: 79
    Thanks "gradek83" for help
    So that's how I started from logging in through the browser and it did not do anything, then in the Samsung account settings, Phone profile I entered the password but the problem is still there. I have a little problem with finding this option "Security and Device Information" but I found something similar in the "Device Maintenance" section
    Here is something like "Device security"
    but there are only anti-virus options inside.
    I do not think I have this option, or maybe I just can not find it.
    I will add that I changed the password as recommended by Samsung every 6 months.
    Maybe I should delete this account and create a new one, all in all I have Google on my backup.
    And as for the backup of Samsung, I have such an error (305) in the Samsung Cloud section, it looks like this:
    Thanks again for your help.
  • #4 16734878
    gradek83
    Help: 930
    Rate: 2103
    Go to your cloud options and account there should be a SAMSUNG account and its settings. I have an android 5.1 so it's a bit different for you.
  • #5 16736282
    kriss1974
    Rate: 79
    I have no problem finding Samsung account settings on the phone, moreover, I replied to your message: "in the Samsung account settings, Phone profile I have entered a password but the problem is still"
    You asked me for this in order to set a password in the Samsung account settings in the profiles tab and I did so but the problem is still there.
    One thing I can not find is: "bookmark, Security and Information about the device" that you asked me before to find this option but I do not have it in S6.
    For me, the Samsung account on the phone looks like this:
    Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6. Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6. Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6. Samsung Galaxy S6 - Continuous login to the Samsung account on the Galaxy S6.
    How do you think it would be a good idea to delete Samsung account on the phone to register a new one?
  • #6 16736440
    gradek83
    Help: 930
    Rate: 2103
    Do not do this
    It's almost you now click on the PHONE PROFILE type in the password for your SAMSUNG account and there you have the Security tab and the Device Information option.
    And if you are logged in to another device, you can log out.
    But finally delete the Samsung account from the phone, reboot it and log in again, or add an account from scratch.
  • #7 16736488
    kriss1974
    Rate: 79
    I've already written to you twice that I typed the password in the profile tab but after logging in the login page will come back.
    OK, I will delete this account and see if it will surprise.
    Added after 10 [minutes]:
    I can not delete my Samsung account, I click delete account, then OK for confirmation and then I am redirected to the login page and on this page it is old, I am going back to the login page after logging in.
  • #9 16737301
    kriss1974
    Rate: 79
    gradek83 wrote:
    Go in here and log in and say if he will let you
    Yes, I logged in here
    Later on this page I deleted the account and registered the renewal but it also did not help.
    Added after 27 [minutes]:
    I feel something that I will do the full system format and install it again. What do you think ?
    Added after 30 [minutes]:
    Here I made a video on YT with this problem in Galaxy apss.
    https://www.youtube.com/watch?time_continue=1&v=vYDyc-ZQR14
    gradek83
    Help: 930
    Rate: 2103
    Check out this option, go to find my device with you tracage du mobile and expand there and there is an option to unlock my device. Alternatively, if you have a Google account on this phone and you want to decide to reset and somehow want to restore factory settings will call the password for the account Samsung and after entering it will not work, so it will be the same problem if you have a Google account on this phone you can remotely clear the phone and all accounts should be deleted.
    https://myaccount.google.com/device-activity
    https://myaccount.google.com/find-your-phone
    Here, dude shows you how to do it generally, you must have a phone connected to the internet. Remember all data from the phone will be erased for how you have a card inserted with data or on the internal memory of some files make your own copy.
    Alternatively, you can clean your mobile device from the Samsung account.
  • Factory reset after deleting Samsung account fixed login loop
    #11 16744237
    kriss1974
    Rate: 79
    At the beginning, SoRRy "gradek83" but too many things fell on my head.
    The board with factory settings has worked and the Samsung account is no longer a problem.
    First on PC I deleted Samsung account then I made reset to factory settings and after the trouble.
    Thanks for the help because on two other forums I described this drawback of the Samsung account but even nobody tried to write anything, so it's cool that you immediately rushed to help.
    Until next, hey.
The discussion revolves around a persistent issue with the Samsung account on a Galaxy S6 device after upgrading to Android 7.0. The user experiences repeated notifications stating "Samsung account, Session has expired," preventing app installations from the Samsung store. Various troubleshooting steps are suggested, including logging in via the Samsung account website, changing the account password, and checking device settings. Despite these efforts, the user struggles to find specific options in the settings and is unable to delete the account due to redirection to the login page. Ultimately, the user resolves the issue by deleting the Samsung account on a PC and performing a factory reset on the device, which restores normal functionality.
