Installation of a video recorder "permanently" in the car.
elektrostarman 8424 3
  • #1 16735744
    elektrostarman
    Hello. I would like to mount a video recorder, not to the cigarette lighter socket, but to permanently install the car's electrical system through the power adapter. I do not know where to do it to be optimal and do not interfere with other electronic / electric devices.
    I mention that I own a Fabie II estate. I'm going to buy Xiaoyi Yi Dash Camera 2.5K / 2,7 "/ 165
    Thank you in advance for any help.
    • Installation of a video recorder "permanently" in the car. yi.jpg (55.12 KB) You must be logged in to download this attachment.
    • Installation of a video recorder "permanently" in the car. a22a5978324e2a0e868f5b4ba2dce4c7.jpg (68.2 KB) You must be logged in to download this attachment.
  • #2 16735751
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6411
    Zap zap where voltage is after the ignition.
  • #3 16735768
    maurycy123
    Conditionally unlocked
    Help: 225
    Rate: 736
    But this eliminates possible recording at a stop. If the lighter has the power all the time, I would attach it to her beam. Possibly before the ignition where there is tension but not "after". And of course I would add a separate fuse to this power supply.
  • #4 16735809
    tzok
    Help: 3174
    Rate: 6529
    In Fabia there is a voltage on the lighter socket after switching off the ignition, but I do not know if I would have the courage to leave a Chinese device with a Li-Poly battery connected to the charging in the car without supervision.
