Chrysler Grand Voyager 2.8 CRD - Crankshaft Lock Position, Pin Placement, 3 O'Clock Stamp
kubas10 11238 4
  • #1 16741684
    kubas10
    Help: 42
    Rate: 1547
    Hello, where is the crankshaft stuck in this car?
    Added after 16 [minutes]:
    Where should I put the lock? I know that the stamp on the shaft wheel is at 3 o'clock, but where should I put the pin?
  • #3 16747220
    kubas10
    Help: 42
    Rate: 1547
    The topic is exhausted, I close.
  • #4 16755565
    kubas10
    Help: 42
    Rate: 1547
    Gentlemen, after replacing the head, the car burns to the touch and the cylinder does not burn on a hot engine. How it cools down is ok and so on. Today, on a hot engine, I took out the injectors to see the compressions and by turning the starter on the 1st cylinder, it was blowing oil from the piston all the time. What's going on?
  • #5 17737148
    MarcinCzup
    Rate: 9
    Hello, I cannot locate the point on the flywheel in Wojtek in 2.8 CRD 2005
    Moderated By CameR:
    Reg. 3.1.19. Do not send messages on archival topics if this is another question, especially other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
